Results 1 to 20 of 20
Thread: turbo civic wont start
    Oct 2010
    Default turbo civic wont start
    Ok I just finished up my b16 turbo swap into a eg.
    I've had it running before. idling for a few seconds, then it just died for some reason.
    it's getting fuel and spark. it turns over, and everything just WON'T start up for some reason. it's really close to starting though.
    any ideas?
    Greene/Athens
    Check timing and compression
    McDonough
    Are we sure it's getting fuel and spark?
    Bitches love bacon.
    Oct 2010
    timing is good, compression is good.
    and i know for a fact its getting fuel. spark plug wires are getting spark, starter is good, etc.
    McDonough
    Sensors plugged in?
    Bitches love bacon.
    Southside Ridin HATCH
    Check all grounds...
    And what did you do, To make sure you had fuel?
    Oct 2010
    yup all sensors plugged in.
    ok, i'm no electrician.. lol. theres a ground from the negative terminal, can I just bolt it up to anywhere on the frame? and theres another ground from the postiive terminal, thats hooked on the starter.. it started fine a few days ago. now its close as hell to starting but it wont.
    and I took the hose off the fuel regulator, fuel was coming out
    McDonough
    That wouldn't be a ground coming off the positive terminal. What about the ground on the transmission that goes to the chassis or the ground from the valve cover to the chassis?
    Bitches love bacon.
    Oct 2010
    the ground from the transmission is not hooked up to the chassis. (i'll do it tommorow) and theres a grounded bolted from the valve cover to the chassis already.
    McDonough
    If you have a minute to type a reply, you have half a minute to bolt that ground to the chassis. Do it and get back to us.
    Bitches love bacon.
    Oct 2010
    lol, I live with my parents, I'm not gonna try to crank a loud as hell car up right now
    McDonough
    Tighten the ground and turn it over for a second or two. If it cranks then you know it worked. Doesn't take but a second unless they are already asleep.
    Bitches love bacon.
    locust grove
    another thing that i did on my first swap..... make sure you lined the dizzy up correcly... if you have to force it in it isnt right... sounds dumb but if its 180* off it may run a little
    i had the exact same thing happen before and that was my culprit, i admit to being pretty stupid for doing that but i did it. also the dizzy went bad from that so had to but another 300 dollar dizzy
    Oct 2010
    my buddy put the dizzy on it, put it on wrong, didnt start so I put it on right and it ran
    McDonough
    So, is it running now or isn't?
    Bitches love bacon.
    Oct 2010
    I'm gonna do it in the morning, lol. I have a small like wire/ground that hangs from the frame right ABOVE the transmission? Can I put it anywhere on the tranny? any other grounds?
    McDonough
    There is a hole on top of the transmission that a bolt goes into. Ground it there. I think the bolt is a 14mm or something of that nature.
    Bitches love bacon.
    Oct 2010
    I did that, still not starting
    Lindale aka B.F.E!!
    had the same problem w my teg forgot to hook up the ground from the tranny to chassis same as ur explaining....also if all vaccum lines on the IM arent hooked up/plugged it will backfire and hard to start...
    McDonough
    There are so many factors to cover. Too bad he got banned. Otherwise, I would offer to head out there to physically look at it to help him.
    Bitches love bacon.
