Results 1 to 11 of 11
Thread: Sr20det 300hp?
    Default Sr20det 300hp?
    I have a stock blacktop sr20det what upgrades would be critical to reach my goal of 300hp. I want it reliable it is a daily driver
    Injectors, something to tune with, z32, bigger turbo, downpipe,exhaust, rocker stoppers, headstuds for safety.
    McDonough
    SRs aren't that hard to squeeze power out of even with a stock turbo IMO. Majority of what's listed above and up the boost.
    Bitches love bacon.
    i have 3 inch downpipe and straight pipe exhaust i will have a boost controller soon and im trying to get it lowered and some wheels before i do the motor mods its being painted right now so i havnt got to do much with it but will after i get it back
    Projects
    Message my bro BLKMKII he just got a Blacktop and its got around 300HP if not more i know it has cams and bigger BOV,Injectors etc...
    Broke sullen's Avatar
    Acworth
    who cares, it's an SR... go for a KA-T build instead and be cooler.
    NC
    McDonough
    Or he can use what he already has and go from there
    Bitches love bacon.
    Lowering and wheels wont get you any closer to 300, make a list of priorities.
    早すぎる TougeGTR-33's Avatar
    I have had many. all you need its a gt28rs, a EBC (electronic boost controller), 550cc injectors and a z32 MAF I would DEF recommend a tune. get an enthlapy ecu from enjukuracing.com just tell them your setup and they will send you a base mapped ecu. ($400) your clutch wont last too long and anything over 350hp your tranny will fail.
    of course you know you will need a 3 inch exhaust, dp etc etc, and walbro 255lph pump too. also recommend a z32 fuel filter. and get some BKR7E ngk spark plugs the gap should be 0.28-0.32.
    Unknown
    550cc injectors, which if you go cheap you can control with stock ecu and a safc but i wouldnt recommend, z32 maf and fuel filter, 255lph, id get a 2871 so you could made 350 if you wanted. and at very least a rom tune. cams would help but not needed for 300whp.
