Thread: Radiator expanded help!!!!!!!!!
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    Default Radiator expanded help!!!!!!!!!
    I have a 94 civic with a b20b, and the car would heat up when its been left to idle but when you drive it it would cool down and go to normal temperature. When it cooled down I opened the radiator and air came out so I filled it up and drove it it ran fine then a day later it did the same thing this happen two more times and i notice the radiator had expanded out wide it looks like a cheap aluminum radiator.I was just wondering why this is happening before I replace it. Thanks and how do you rep on here.
    b20b is in!!!!
    b20b vtec coming real soon!!!
    McDonough
    Click the little star at the bottom of your post to the right of Blog This Post.
    As for the radiator, no clue. I can't even comprehend how it would expand.
    Bitches love bacon.
    barrow county
    starting off, your losing water/anti freeze.
    does the car smoke? white ish blue?
    sign of any leak from radiator? hose?
    if the radiator was a cheap one, when starting to over heat, the water/ anti freeze push the cheap aluminum outward ( weak walls )
    normally it'll stress the radiator and this is how many bust open.
    do you have a fan on it any chance?
    Jul 2009
    N. Philly
    no smoke no smell off burning anti freeze checking the hoses today
    b20b is in!!!!
    aye bro .:Stirfry:.'s Avatar
    buy a new cap. you probably have air in the system. and do you have a over flow bottle?
    ATL DAsquad Member #9
    Jul 2009
    N. Philly
    switch radiator and tighten hoses and car runs fine thanks
    b20b is in!!!!
    Dec 2008
    Northside
    It was most likey ur cap. Wrong cap with higher psi Wil cause this
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
