Thread: 93 civic hatch with gsr swap, AC question
    Senior Member Schugg's Avatar
    Default 93 civic hatch with gsr swap, AC question
    trying to remember if its possible and what parts are needed from what cars to put ac in a gsr swapped 93 hatch. right now the only AC related part in the car is the dash controls and wires.....none of the lines, condenser, compressor, evaporator or any of that. anyone know of a what needed from what or any sites that have it listed?
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    also was a obd2 swap
    - 2008 Acura TL-S
    only thing you really need is to use all your civic stuff, and a b16 driver side torque mount. Wiring will not change, and you can't use the integra anything unless you have custom lines made. And your car is all r12 stuff and all the lines are different than the 94 civic which came with r134a. I promise, EVERYTHING between a 93 and 94 ac system is different.
    My line of work
    www.internationaljets.com
    Quote Originally Posted by Starrfire View Post
    you cant use a b16 mount. you have to use either the del sol or crv mount. you will need all of the civic parts besides that.
    excuse me, you're telling me I can't do something I have done before. An what engine does the del sol have? you can also use an sir2 one.
    My line of work
    yes im telling you that you cant do it. look it up. the del sol has a b16 in it but its not the same one that the si has. its a mount that mounts to the b series motor and uses the d series compressor. there is only 2 that do it. i wasnt trying to fight with you over this but im sure that you ran the b16 (del sol) mount. you cant just use any b16 one.
    I never implied em1, I was staying around the 5th gen civic body. Both b16 cars, just not 6th gen civic. I wasn't specific enough I guess.
    My line of work
