Results 1 to 10 of 10
Thread: H22 keeps blowing head gasket
    Boostin, yo!
    Oct 2008
    covington
    Default H22 keeps blowing head gasket
    I just put a H22 in my wifes accord and it keeps blowing head gaskets. Any ideas why? I bought brand new ARP head bolts. Torque spec is 80fp and I torqued it down to 100fp this last time. I hasnt overheated either...
    Southside Ridin HATCH
    Coolant hoses are correct place?
    What gaskets are you using?
    head or block might be warped.
    About to approach beast mode
    ^^ If your doing everything correct..
    that IS probly your problem right there...
    ALWAYS get the heads checked out before putting back on.
    How do you know it keeps blowing the head gasket? You can stretch ARP bolts by over torquing them, and if it hasn't overheated what makes you think its a headgasket? I would pressure test the system, and make sure fans, and radiator cap, temp sensor are all in working order.
    And as stated prior, the head or block can be warped, or have hairline crack somewhere.
    aye bro .:Stirfry:.'s Avatar
    two words
    indian head gasket shellac compound!
    get it at your local part store, best couple dollars youll ever spend.
    ATL DAsquad Member #9
    Feb 2010
    Zebulon
    shelllllllllac....
    warped head/block x 3.
    Boostin, yo!
    Oct 2008
    covington
    Yes, i got the head milled, and the block decked. it is all good. I know it is blowing headgaskets because it sounds like a wrx, and lost some compression in cylinders 3 and 4. It is an oem gasket, the radiator hoses are in the correct places. and all coolant sensors/system is working properly. After i let it sit for about a day and cranked it, it was blowing white smoke. bad. Can a machine shop check to see if the head is cracked?
    Feb 2010
    Zebulon
    they do a vacuum test to see if it cracked.
