Results 1 to 15 of 15
Thread: need help 1992 integra
    FREE BUJU StarBwoy's Avatar
    IDK
    Default need help 1992 integra
    how do you kno that your fuel pump not working
    1.i check to see if the motor is gettting fuel /no fuel
    2..i check all fuse and relay/all good
    3.check to see if the fuel pump makin any noise/no noise at all
    and will a 1994 honda civic fuel pump fit a 1992 integra
    will give reps for any info thanks
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    McDonough
    When you turn your ignition to the ON position, do you hear it cutting on?
    Bitches love bacon.
    IDK
    no sir no sound of it turning on
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    IDK
    need some help here guys
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    number 3 statements of yours tells it all. You could open your gas cap and listen from there to see if you can hear it.
    McDonough
    If you don't hear it turn on, then likely the fuel pump went bad. I have two stock EG fuel pumps if you want to try one/if they will work. If it works, you can have it.
    Quote Originally Posted by jdmalltheway View Post
    You don't have to open the gas cap to hear it cut on.
    Bitches love bacon.
    barrow county
    Could be relay
    Chickens Eat Eggs
    south side hoe
    fuel pump relay beside the main relay the black one
    Chickens Eat Eggs
    south side hoe
    also the main relay change both out
    Chickens Eat Eggs
    south side hoe
    if not fuel pump yo
    IDK
    why thank you sir
    yea it loud
    Quote Originally Posted by laokid View Post
    hold on there two relay boxes becasue i have a black 1 and brown 1 that came with the car in the glovebox?
    when i bought the car there were 2 relay boxes in the glove compartment so i plug up 1 of them where does the other one go ?
    but when i plug it up and turn the key to on position the relay makes a click sound but no fuel pump noise
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    McDonough
    Quote Originally Posted by jdmcivcc View Post
    yea it loud
    What's loud? I'm confused here.
    Bitches love bacon.
    Chickens Eat Eggs
    south side hoe
    the brown relay is your main relay, and the other one is ur fuel relay i think, black i dunno i had the same problem with one of my da's, i just change those two out, u can feel it click if u hold the relay in your hand while u turn the igition on ...and when ur on the key to the ON postion last turn u should hear the injectors squirt than ur fuel pump is working....
    IDK
    lol the fuel pump
    ok i see the brown 1 but the 1 next to it is small and black is that the fuel relay
    and i tested the fuel pump it works
    and my cuz said that the ecu may be broken?
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    McDonough
    So, the fuel pump IS working. So what's the problem?
    Bitches love bacon.
