Results 1 to 5 of 5
Thread: 94 teg LS major brake problem.. please helpp
    Certified Gearhead jfryer496's Avatar
    Feb 2010
    Phenix City, alabama
    Default 94 teg LS major brake problem.. please helpp
    alright. well i let my car sit for about... 3 weeks and when i got back in it the brake pedal went straight to the floor. barely works. but sometimes they work and sometimes they dont. i tried bleeding them and it helped for a bit then just started doing the same thing.. could the master cylinder be bad? the ABS module had a hole in the cap and i put a new cap on it.. could it have gotten alot of air in it somehow ? what should i do to diagnose the problem? ANNYYthing is MUCH greatly appreciated! thanks!
    -jeff
    KINGZOFSOUTHTOWN
    Norcross
    Try these if you havne't
    1. Brake Master Cylinder
    2. If you got a brake master cylinder (new) make sure you bench bleed the master cylinder
    3. Maybe your bleeding wrong, don't do them individually you will not get all the air bubbles out, from what your saying, sounds like your master cylinder is good b/c it would not work good sometimes and not sometimes unless you bled it wrong. What you can do is lift your car on all 4 jacks, take off all 4 wheels and open up all your bleeder holes and every about 10 - 20 add more brake fluid to the container. just let gravity do it's thing..
    4. Your brake booster has gone bad
    hope this helps...
    -hmgdrfter-
    PP TRACK 350Z
    Feb 2010
    thanks soo much dude! let me see what i can work up cant say thanks enough !
    Feb 2010
    Zebulon
    bleed the brakes completely. i would advise against the gravity bleed, it allows a good bit of air in.
    Feb 2010
    i bled the whole ABS module, all 4 brakes and even the master cylinder.. still the same. pedal feels good then it just dies and goes to the floor and the brakes barely work, im thinkin it its the master cylinder.. i got one whats the proper way to bench bleed it
