Results 1 to 14 of 14
Thread: boiling in overflow reservoir
    Senior Member cm7k24's Avatar
    kennesaw
    Default boiling in overflow reservoir
    i've noticed every time i turn my coupe off after driving a little bit i hearing boiling sounds
    and found that radiator overflow reservoir fluids are boiling for a minute or 2 then stops.
    what does that usually mean?
    Projects
    it could be just full and purging excess water or mean that the radiator is getting poor circulation or thermostat going bad. Whats the hand read even though id never trust a oem gauge ?
    kennesaw
    its running at perfect perfect temperature ( from what the gauge reads lol)
    Projects
    hmm have you filled the radiator up recently or topped it off ?
    Also how good is the fans blowing or coming on ?
    WEST_SIDE
    check your radiator cap, a radiator cap helps pressurize the cooling system.
    correct pressure raises boiling point. seems like your cap could be the cause. of course im just going by what u are saying.
    Norcross
    i think i read somewhere that a bad headgasket will cause this.. i may be wrong
    Quote Originally Posted by j0nbunklah0m View Post
    That's what my old sedan engine was doing when I bought it, bubbles all the time. Turns out it was obvious after I thought about it. It was compression being blown into the coolant system all the time. I'd be afraid to take it on a long drive.
    My line of work
    www.internationaljets.com
    RedHenRacing #02 Stuntman G's Avatar
    Jul 2009
    I can say a bhg will definitely cause this, I had an EF that did the exact same thing. It was fun to pull the spark plugs and turn the engine over and watch the water shoot out of the cylinders lol
    INSIGHTFUL DIALOGUE ANALYSIS: Actually, Hector, that is not what we call valet parking. Valet parking is where someone parks your car for you. You just pulled your car up to the front of the store and got out. We just call that parking.
    I MAKE THESE
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    definitely a blown hg.
    98 Acura Integra LS-DD
    ??????????????????-project
    Northwest Georgia
    be careful it might not be a blown gasket. It could just be an air pocket in the coolant or radiator sucks...is it a stock engine...built....turbo?
    I know i had a fresh build that was over heating like no tomorrow...tacking out the sensor and boiling over craziness...i bled and bled and added and added and it fixed itself. this was like 5 or 6 years ago.
    WEST_SIDE
    If u trully think it's your head gasket Do a block test, the kit is only like 20 bucks, appose to buying the headgasket set and still having the same problem after a few hundred bucks.
    AccuracyPerformanceAutomotive
    ^--- This. We see it all the time at work.
    500whp of spinnin fury!!!
    Apr 2010
    had the same problem on a 94 ex, changed the radiator and it never gave me any trouble after.
    Mar 2010
    Rome
    my 92 accord does the same thing. it had an air pocket in cooling system 0_0
