Results 1 to 4 of 4
Thread: LS-VTEC QUESTIONS?
    Certified Gearhead deondre's Avatar
    Jun 2010
    Default LS-VTEC QUESTIONS?
    hey IA i believe my head gasket is going, and i've got quoted like 450 to replace it!
    needless to say, instead of doing that im interested in doing lsv. im on a tight budget, i do not care for making alot of power or reving past 7k.
    can i not touch the block ( mine is fine)
    what all would i need to build one? vtec head, golden eagle kit? ( i have a dizzy) vtec ecu?
    does anyone know how much mainstream would charge to do lsvtec?
    the only thing i have is a dizzy and my ls.
    looking for someone who has done it. any insight is greatly appreciated.
    Ideally you need an lsvtec kit, comes with all required hardware,headgasket, offset dowels and sandwich plate...they are usually in the area of 220$... then you need a head which is 400 ish, and an ecu either needs to be chipped, or run a vtec ecu, plus necessary wiring,plugs, and the cost of swapping heads.
    If your budget is 450 and under, this is not for you. I would recommend fixing what you have. If you have in the area of 1000+ to pay someone, parts and labor. Then this is for you..
    Jun 2010
    im looking to spend around 1-1.2k? is that reasonable?
    Oct 2008
    You gotta pay to play. LS/VTEC is not for people with light wallets. Plus it would be a waste to do a LS/V without atleast changing your rod bolts because your stock bottom ends rev limit would be way lower than where you would be making peak hp. As Emmino said I would fix what you got and save up so you could properly do an LS/V.
