Thread: H22a accord vtec problem
    zoom-zoom 94_cd5's Avatar
    buford
    Thumbs up H22a accord vtec problem
    Ok so i had a usdm h22a1 in the car before and it spun a rod bearing so i put the jdm h22a in everything works exactly how it should but vtec. it wont come on at all and the car redlines at 6500 for some odd reason since vtec isnt working maybe in some kind of limp mode. if any 1 can help me get vtec working i can throw them some $$$ i live in the buford area pm me on here with and suggestions thanks!!
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    May be an ecu problem
    98 Acura Integra LS-DD
    ??????????????????-project
    is it obd1 or obd2? because obd2 doesnt accept jdm h22s to my knowledge.
    CD5 Accord
    Atl
    im in suwanee. are you thorwin any codes?
    credibility and reputation
    Quote Originally Posted by 94_cd5 View Post
    you need to check the vtec soleniod to see if its getting power, you can send 12v to the vtec soleniod and if it clicks, its still good. also check your old motor to see if it has a crank position sensor behind the timing cover. the jdm motors crank sensor is in the distributor. so you will need to take those parts off the old motor and put them on the new motor, if its behind the timing cover.
    About to approach beast mode
    buford
    no codes are being thrown and its obd1
    Quote Originally Posted by HatchHero View Post
    buford
    ya we checked vtec and it had 12v going to it so idk im gonna check on the old motor its in the garage
    Quote Originally Posted by K24cb7coupe View Post
    buford
    any other help out there? wanna get this up and running right
    buford
    i might be throwing a code not sure idk if my cel light works it doesnt flash when i turn the car on so the bulb might be out
