Thread: QUICK brake question
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default QUICK brake question
    okay so coming home from work stuck in 285 traffic, from all the brakin i came to hear a tickin noise coming from my driver side rear brake, when the car is runnin and im slowly brakin is ticks...
    i gave a shot in the dark and thought it was my blown shock, changed it. & still same problem
    so now im thinkin it could be the disc or pad thats un even .. so wat could be causing this problem???
    also when the car jumps in any type of bump, something rattles from that area.. if anyone can plz help me. reps will be given
    maybe the caliper,disc,brake pad??
    del sol? 94_teg_ls's Avatar
    you may have lost a shim
    /sig
    With Your Mom
    Quote Originally Posted by 94_teg_ls View Post
    i might sound dumb but whats a shim?
    the little metal clips that you slide the pads into when changing the brakes
    /sig
    With Your Mom
    that can cause it to tick??? and somethin rattles too in the brake/wheel area
    that could be a lot of things but if you hear a tick when you first brake the pads are sliding or a worn guide pin but thats unlikely
    /sig
    With Your Mom
    tomorrow im changin the rear pads to see if anything changes, if not ill look into the caliper an disc.. im keep you updated man.. reps++
