Thread: I need alot of help on a lsvtec build
    Default I need alot of help on a lsvtec build
    Kind of new to ia so i dont know if i should post this on this thread but here it go anyway.
    I have just got this shell with a ls motor and tranny; I was planning to buy a b16 head to go for vtec. So the question would be what should i use for internal for the block and head so that it would be good if i would like to go boosted later?? I mostly just need help on what is mantory n good for me to go boosted later. Appreciate your time
    your moms house
    it really depends on what your goals are leter down the road
    Well later down the road i just want to go boosted and be reliable
    your moms house
    i mean power goals that will make a big difference in the parts you need
    Truly man idk, jus trying to get pretty close to 300 hp is my main goal
    TheMyth
    should have posted this in the boosted section if you want to go boost. golden eagle makes a oil filter sandwich plate that will give you a oil prt to feed the head, and can T off that to feed your future turbo. but you ought to think of maybe eagle rods, forge pistons, springs/retainers, and the fuel setup to deliver the power that you desire. if you want 300whp, you could always run 750cc injectors and that will allow for growth later on from there. for 300whp, you dont have to get crazy with the build. and it will be reliable.
    McDonough
    Before you do anything, do your research and see how people built their motors. You can boost on stock rods and crank but the pistons are recommended to be changed. Tuning is where you don't want to skimp out. You can build a motor with 20+ pounds of boost and still be reliable as long as it's tuned properly; likewise with an all motor LSV build. Tune it right and it will last. Become friends with Honda-Tech and Google.
    Bitches love bacon.
    Northwest Georgia
    Pistons: Arias, Wiseco, Manley, JE
    Rods: Eagle, Manley make great h beams for 350 or less.
    do you know what your goals are yet lol....what about budget...do you have a budget?
    Certified Gearhead willard's Avatar
    Aug 2009
    columbus, GA.
    stay NA
    SLEEP, EAT, RACE
    McDonough
    Quote Originally Posted by willard View Post
    stay NA
    that's why he posted in this section.
    Bitches love bacon.
    Jan 2010
    We can do business
    IF your not planning on breaking over 300 if you boost in the future and still have a decent NA then I would leave the stock ls pistons in it and get rod bolts head studs.... valve springs and retainer and a mild cam that can be used on boost aswell as NA. this is not too great but is as close as I can come to what you are trying to get... of course this is if you are on a budget if money is not a concern then I would decide right now whether I am doing boost or all motor and go all out.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    me and a few customers started out with only this to break 300whp! stock ls motor with ARP rod bolts,vtec head of your choice,450-560cc dsm injecors from turbo talon,eclipse or 560s from an evo with driver box from older civic/integra obdo car, the 450ccs net around 275+whp at about 90% duty cycle and the 560ccs go to around 335+whp,and i recommend head studs cause some of us got head lift some didnt i ran em so i didnt!lol. stock head gasket.stock valve train,valves and springs and stuff are good for pretty high hp numbers. and most importantly get chipped n tuned mine was done by scotty at mainstream and tuned on crome gold! good luck and remember research,research,research! also you can do this even with all stock parts but will be more reliable this way if your funds permit!
Tags for this Thread
