Thread: Jdm b20b idling problems!!!
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    Default Jdm b20b idling problems!!!
    I just put this motor in my car it starts up and sounds good but won't idle and when it does its less than 500rpm. head has had valve job. i'm just lost
    b20b is in!!!!
    b20b vtec coming real soon!!!
    McDonough
    Tried adjusting your idle screw on the TB?
    Bitches love bacon.
    aye bro .:Stirfry:.'s Avatar
    checked the timing
    ATL DAsquad Member #9
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    I say timing issue.
    98 Acura Integra LS-DD
    ??????????????????-project
    Jul 2009
    N. Philly
    i tried the tb screw, see wen i first started the car it idle just fine for 10mins then the rpms fell and motor died out ill check timing tomorrow and see if the map sensor and the tps plugs to make sure there not switched. car still starts up tho jus got to keep it on with the gas pedal.
    b20b is in!!!!
    McDonough
    http://www.importatlanta.com/forums/...ttered-gt-died
    Read up on my thread posted a while ago. Sounds almost like the same thing.
    Bitches love bacon.
    Jul 2009
    N. Philly
    ok, i'm check the timing tomorrow but it's a brand new timing belt
    b20b is in!!!!
    Jul 2009
    N. Philly
    thanks for the help!
    b20b is in!!!!
    Jul 2009
    N. Philly
    re did the timing and car idles at about 700 rpm
    b20b is in!!!!
    checked all your vacuum lines/caps and intake manifold gasket?
    Jul 2009
    N. Philly
    is there any way to bring the idling rpms up i cleaned the ficv and the iacv no vacuum leaks play wit the tb screw and rpms are at 700 rpms
    b20b is in!!!!
    Titties!!!
    check your timing. make sure to jump the service connector first or the ecu will over ride it. also i think the IACV has to be disconnected while adjusting the throttle screw. i have a book that covers your motor so i can tell you what to do if needed. pm me if you want.
    your rpm at idle should be 750 + or - 50 rpm so if you do the screw unplug the IACV to bring it up to 750 rpm.
