Results 1 to 5 of 5
Thread: F22A/F22B Wiring harness
    Default F22A/F22B Wiring harness
    I'm swapping an DOHC F20A into the Prelude. I know the F22A harness will work, but it's hard to find one thats OBD1. However, I did find an F22B2 (accord) wiring harness in OBD1. Question: Are they the same? Or close enough?
    92-95 prelude h23 harness will work better. As far as the 2 harnesses mentioned, they are the same except for the plugs that connect to the chassis side harness. And 90-91 ex f22a are internal coil, all other f22a's are external coil. hope that helps ya out.
    About to approach beast mode
    So an H23 harness will have the same plugs for all the sensors on an dohc f20a?
    Just modify what you have. its easy. and its less bullshit you know it works since it came out of YOUR car.
    Feb 2010
    Zebulon
    agreed. the h23 harness will suit you better, lable all of your plugs when you pull it off the motor. take pics if necessary. it will help you quite a bit later on, you will not have to resort to manuals, wiring diagrams or your friends car.
