Thread: Shutter actuations
    Senior Member antiv6's Avatar
    g-nett
    Default Shutter actuations
    can someone tell me exactly how many pics this camera has taken? Here's a picture, thanks!
    http://i26.tinypic.com/t6dwys.jpg
    goeie bliksem! r0bb86's Avatar
    Noo'n/\n
    g-nett
    thanks if you get some time later could you explain how you found that out. no rush
    lost 4 valves chriskm's Avatar
    Dec 2009
    Newnan, GA
    Google "irfanview". Download it. Go to the plugins page, and download the misc plugins zip or the entire archive. It'll give you some .DLL files to put in the IrfanView plugins folder. One of those is EXIF. Open an image in IrfanView, then press I. It'll open up an information dialog. There's a button for EXIF info. The number you're looking for is "Total Pictures". Easy-peasy.
    Make - NIKON CORPORATION
    Model - NIKON D40
    Orientation - Top left
    XResolution - 300
    YResolution - 300
    ResolutionUnit - Inch
    Software - Ver.1.10
    DateTime - 2008:10:18 19:06:56
    YCbCrPositioning - Co-Sited
    ExifOffset - 216
    ExposureTime - 1/100 seconds
    FNumber - 3.50
    ExposureProgram - Not defined
    ISOSpeedRatings - 200
    ExifVersion - 0221
    DateTimeOriginal - 2008:10:18 19:06:56
    DateTimeDigitized - 2008:10:18 19:06:56
    ComponentsConfiguration - YCbCr
    CompressedBitsPerPixel - 4 (bits/pixel)
    ExposureBiasValue - 0.00
    MaxApertureValue - F 3.48
    MeteringMode - Multi-segment
    LightSource - Auto
    Flash - Flash fired, auto mode, return light not detected
    FocalLength - 18.00 mm
    UserComment -
    SubsecTime - 00
    SubsecTimeOriginal - 00
    SubsecTimeDigitized - 00
    FlashPixVersion - 0100
    ColorSpace - sRGB
    ExifImageWidth - 3008
    ExifImageHeight - 2000
    InteroperabilityOffset - 25586
    SensingMethod - One-chip color area sensor
    FileSource - Other
    SceneType - Other
    CustomRendered - Normal process
    ExposureMode - Auto
    White Balance - Auto
    DigitalZoomRatio - 1 x
    FocalLengthIn35mmFilm - 27 mm
    SceneCaptureType - Standard
    GainControl - None
    Contrast - Soft
    Saturation - Normal
    Sharpness - Normal
    SubjectDistanceRange - Unknown
    Maker Note (Vendor): -
    Data version - 0210 (808595760)
    ISO Setting - 200
    Color Mode - COLOR
    Image Quality - FINE
    White Balance - AUTO
    Image Sharpening - AUTO
    Focus Mode - AF-A
    Flash Setting - NORMAL
    Flash Mode - Built-in,TTL
    White Balance Adjustment - 0
    White Balance RB - 674
    Exposure Adjustment - 68608
    Thumbnail IFD offset - 2650
    Flash Compensation - 67072
    ISO 2 - 200
    Tone Compensation - AUTO
    Lens type - AF-D G
    Lens - 758
    Flash Used - On camera
    AF Focus Position - 33554433
    Bracketing - 0
    Color Mode - MODE3a
    Light Type - SPEEDLIGHT
    Hue Adjustment - 0
    Noise Reduction - OFF
    Total pictures - 4449
    Optimization -
    Thumbnail: -
    Compression - 6 (JPG)
    XResolution - 300
    YResolution - 300
    JpegIFOffset - 25724
    JpegIFByteCount - 10807
    paint booth
    download opanda.
    g-nett
    thanks everyone i downloaded opanda and it didnt show it for some reason
    paint booth
    make sure to click exif and its nine lines up from the bottom. you will see "total number of s..."
