Thread: Civic AC
    Default Civic AC
    ok, i have a 1996 honda civic. when i turn on the ac, its cold for maybe 3 min and starts to get warm agian. yes, i add freon to the car. used 2 bottles, ac got cold and than warm agian. any help?
    McDonough
    Have you checked for any leaks? Go to Autozone or equivalent and get some dye that goes in the lines and check for leaks.
    Bitches love bacon.
    i wanna say your condensor is marginal. Mine temp was marginal at idle but as soon as i hit the highway it would get cooler. Also make sure you don't have any leaks to rule it out.
    when i put on the freon, i saw no leaks anywhere. but the temperature stays at the same spot, doesn't go up and down.
    McDonough
    You may not be able to visually see the leak. You will have to use a dye and a blacklight to see if there is a leak.
    Bitches love bacon.
    Stang Mod slostang's Avatar
    Southside
    hook up a set of gauges and see what your pressures read. low side should be 35-40 and the high should be around 225-250.
    if the low is really low and the high is really high, you have a blockage somewhere. (condenser, orifice tube)
    if the low is high and the high is low then you probably have a bad compressor.
    also try by-passing the low side pressure switch with a paper clip temporarily to see if your compressor stays on.
    a/c is 1 of my specialties. lmk if u cant get it straight.
