Thread: what kind oil is best for a lexus is300?
    IA Member jimmy1988usa's Avatar
    rwd world
    Default what kind oil is best for a lexus is300?
    i know many is300 out there and they use different oil change but i dont know what kind they using? any help please?
    RWD all the way!
    Moved to the correct place. Later, QD.
    Weekly Gwinnett/Junciton Meet
    purpose intended for the car? Mods? Are you having any kind of problems with the oil you are using? What oil are you using? Give a little more details.
    rwd world
    Quote Originally Posted by UpSideDownDesi View Post
    i dont have any problem at all and i use the regular oil from shop, i just wonder is there any special oil is specialy for is300?
    RWD all the way!
    1-3-7-2-6-5-4-8 40th GT's Avatar
    Suwanee, GA
    I doubt it. The 2jz is like other piston engines and it shouldn't demand anything more special than the car next to you.
    As for viscosity, I would go with what the manufacturer recommends, which should be a 5w-30. If you want to treat your car, you can use a synthetic. Some brands that are worth noting are Pennzoil Platinum, Amsoil, and Redline.
    If you really want to get particular about oil, check out www.bobistheoilguy.com/forums - this place will teach you more than you ever wanted to know about oil/car maintenance.
    Mine's the red one.
    ESP
    Mar 2010
    GA 400
    I always have and always will continue to use Full Synthetic oils, whether it be AMSOIL, Mobil 1 or the occasional RP.
Tags for this Thread
