Results 1 to 26 of 26
Thread: √ Engine Light ('96 del Sol)
    Atlanta, Ga
    Default √ Engine Light ('96 del Sol)
    1996 del Sol VTEC (b16a2)
    Alright... ran some SeaFoam through the Slo (brake booster, oil, fuel, the works). Of course it bogged it down when I was running it through the booster, but it recovered quickly... runs like a top still. BUT my check engine light came on.
    It's showing a code P1300 (random misfire) and P0301-0304 (random misfire on all cylinders)
    So I'm wondering what you guys think may be triggering my light. As I said, the car runs great, fuel economy hasn't changed, nothing. I have cleaned the IACV and changed the plugs within the last day and still no change. I'm guessing I fudged up a sensor or something?
    Thanks for any info and reps will be given.
    LAWRENCEVILLE
    have you tried eraseing the codes and see if they come back?
    Hella stock member!
    Middle, Ga
    Hmmmm, thats weird. Try doing what Silversol suggested. I really can't think of anything else it could be besides a sensor, maybe.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    McDonough
    Since those codes became present and you have changed the plugs, D/C your battery for a few and let them clear.
    Bitches love bacon.
    Atlanta, Ga
    yeah i pulled the ECU fuse for about 30 mins and it still came back. that should effectively 'reset' the ECU, no?
    McDonough
    it should but D/C the battery just to be sure. also not sure if it would help or not but check to make sure you are getting spark at all cylinders.
    Bitches love bacon.
    Atlanta, Ga
    disconnecting the battery did nothing. any other ideas?
    McDonough
    Have you confirmed spark at all four cylinders?
    Bitches love bacon.
    Atlanta, Ga
    oh yeah forgot about that lol. what's the best way to go about doing that? i don't have any meters.
    gone old school C-loS109's Avatar
    somewhere
    i would get some rubber gloves and start your car, pull each plug and put it near some metal and look for a spark lol thats what i did.
    =EJ-EG SQUAD SUPPORTER=
    2000 HONDA CIVIC - SOLD
    1966 MUSTANG COUPE - TRADED
    1989 FOXBODY MUSTANG - DD
    McDonough
    PM me your number. I can help you with all of that.
    Bitches love bacon.
    Scottish Scotsman's Avatar
    on the road to recovery
    thats what i was thinkin
    del sol? 94_teg_ls's Avatar
    also just a idea i have had this problem a few times swap o2 sensors sometimes when you sea foam it stuff clogs it.
    /sig
    McDonough
    Not sure a dirty o2 sensor will cause a misfire. Maybe on newer vehicles where the ECU actually gives a shit about there being o2 sensors, but maybe not on an obd1 car.
    Bitches love bacon.
    Atlanta, Ga
    my car is ob2. o2 sensors might be worth changing.
    McDonough
    are they the same plug as obd1? if so, i have one that was pulled from a stock LS header you can try out. hopefully, i can use the stock ones from my sol when I do my swap.
    Bitches love bacon.
    Titties!!!
    it won't work i tried it on mine there is a difference somewhere i think, or i just had a bad obd-1 o2.
    there the same probably had a bad one and HEY i need that 02
    /sig
    McDonough
    Quote Originally Posted by 94_teg_ls View Post
    I will try to get down there to bring you that header. I took the sensor off expecting to use it on my new header and forgot that you needed the stock header back. Will bring it to you sometime this week.
    Mr. Clean, if you want to try my stock sensors to see if that fixes it before you spend money on some, let me know and I will see about pulling them off.
    Bitches love bacon.
    Titties!!!
    try it mine may have been fried. i have a spare but it's kind of on a z6 right now so it's obd-1.
    McDonough
    well mine are on a d16 too but if the plugs are the same, they should work right? before my car took a shit on me, there were no codes.
    Bitches love bacon.
    yeah just take the one off the b20 headers we wanna pick up the z6 soon
    /sig
    McDonough
    Well, come get it out of my car. I need to make room for the
    Bitches love bacon.
    i will trying to get the money up and well ill pm you
    /sig
    It could be spark plugs, wires, coils or the distributor. The cam/crank sensors in the distributor could be contributing to the problem but most likely they are not. Try another distributor with other wires and new plugs and see how that goes.
    Dan
    Atlanta, Ga
    yeah i'm about due for a lot of things so i guess i'll just have to wait to get the cash up and change out the wires and dizzy.
