Results 1 to 29 of 29
Thread: gsr head.
    Boooosted!! kr3w108's Avatar
    Oct 2008
    Bama
    Default gsr head.
    OK I have a few questions . First off is a gsr head on b16 block a waste of time.... am I better off with a b16 head. Second will a b16 intake fit on a gsr head? Thx in advance.
    Best ET 9.69@147 running out of gear....
    video of pass....
    https://youtu.be/Y4ogpwzNpzg
    get sideways! mistergou's Avatar
    Jul 2009
    Chattanooga, TN
    b16 an b18c5 (type r) intake manifolds will swap but the gsr b18c1 is all by itself ...
    dunno on the gsr head on b16 block, but it should work
    usually most people have a gsr block an put a b16 head on it for a poor mans type r setup
    Oct 2008
    Bama
    yes i know about the poor mans type r, i am just curious how the b16 block and the gsr head will do together. the code on the head is p75 idk which modle gsr it is i believe its the c1 but not sure.
    Quote Originally Posted by mistergou View Post
    video of pass....
    P75 is an LS head, B18B1. GSR, B18C1 is P72.
    I like the P72 chamber much better than the P13. The chamber is also a little bit smaller on the P72 as well.
    "What one person receives without working for, another person must work for without receiving"
    Hmm, wonder what it would do for mid range torque on the b16 with the dual stage manifold. sounds like a good thing for it. but a p75 head is an LS head, not a gsr. P72 is 94+ gsr. But it will fit no problem. Just need a different radiator hose.
    My line of work
    www.internationaljets.com
    Oct 2008
    Bama
    I meant to say p72 Idk why I put 75 LOL. I'm thinking ls-v so I may not use the b16 block. Putting my a2 piston in ls block with gsr head and call it a day....
    video of pass....
    college park
    i have that current setup b16 block gsr head basically you get a high compression b16 feels stronger than a b16 to me
    http://www.c-speedracing.com/howto/c...c/compcalc.php
    just change the head to a b18c1 and see the difference
    now with LSD
    Oct 2008
    Bama
    All. My friends say its a waste... what kind of HP you looking at? You took It to a track yet? I'm kind of in the middle of b16 block with a gsr head or ls-v with b16 pistons. I think ls-v will produce the most out of the two.
    video of pass....
    Southside Ridin HATCH
    If you want to do LSV then you should "build" it with internals... IMO
    Also the GSR head on B16 Block is a waste.. Just sell it or trade for a B16 head..
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    poor man type r is great set up if only build it properly
    dont go with the hype of lsv and b20v is great man
    do whatever your budget allow you to do
    R.I.P Booga
    M.A.P
    F.D.L.R
    Out the game again!!
    southside of the border
    ^lsv or b20v built right is great!!!
    Soon!!
    SOUTHSIDE
    ^^^ true man im knocking the build but it gotta be in that person budget also ppl keep tellin ppl that oh you need to this and that not carrying about their budget and stuff oh well im just giving my two cent i wish you a best of luck man with whatever route you go with
    R.I.P Booga
    M.A.P
    F.D.L.R
    Southern Speed
    Macon
    A gsr head on a b16 bottom end would be better than a regular b16 because of the increase in compression and having the gsr cams. But would probably benefit more swapping out the gsr intake manifold to a blox,skunk2,aebs. But i would only do this if you had it laying around. An ls-v will make alot more power and torque all around, if done right. Ls block with b16 pistons can net around 200whp with the right head setup.
    Oct 2008
    Bama
    I don't really have a budget, I have both ls and b16 already in my hands. Just need to decide which path to take. Either way I'm gonna rebuild both . I wanna do lsv and it be reliable.
    video of pass....
    Southern Speed
    Macon
    if you have both then do ls-v just make sure you know what you are doing.
    Oct 2008
    Bama
    Thx man, I will have everything right. Gonna rebuild bottom end completely.
    video of pass....
    SOUTHSIDE
    gsr water pump olil pump and timing belt and balance the bottom end plz
    R.I.P Booga
    M.A.P
    F.D.L.R
    Oct 2008
    Bama
    Quote Originally Posted by jerseyef9 View Post
    Yezsir. I have all that just waiting to put It together. And I plan on balancing the crank.
    video of pass....
    Oct 2008
    Bama
    I used a compression calculator on my computer and it said my compression will be around 12:2 .... I'm thinkin that's a lil high.
    video of pass....
    SOUTHSIDE
    that is not high dude you can tuned that on pump gas and ride out man
    my tuner had simple b16 head with springs retainers and skunk pro 2s and b16piston in ls bottom end made 210
    R.I.P Booga
    M.A.P
    F.D.L.R
    OBD2 B series oil pump...
    12.2 is high but not TOO high were it will be a problem.. just get a tune..IMPORTXP.COM
    Build it right!
    Oct 2008
    Bama
    Sweet, I plan on adding a lil bit of boost with This as well. I'm not looking for big ass numbers just want something fun and reliable.
    video of pass....
    Southern Speed
    Macon
    if you plan on boosting it dont put b16 pistons in it.
    Oct 2008
    Bama
    That's why I was worried about the compression ratio. ...
    video of pass....
    Southern Speed
    Macon
    You could leave the ls pistons in it to put you around 10.18:1 which would be like a gsr with more tq. and that would also leave you with a good compression to boost on.
    Oct 2008
    Bama
    Hmmm... Alright sounds good. As far as the strength of a stock piston what kind of pressure can they stand? Thinking maybe I should buy some forged pistons to go with my new rods.
    video of pass....
    If you have the funds... I would do the Aftermarket forged pistons with Rods...
    sounds like a familiar build
    Soon!!
    Quote Originally Posted by allmotorX View Post
    yessir!
