Thread: how to check obd1 codes
    Post how to check obd1 codes
    ok guys i am going to need help. i did research on this and it is saying use a jumper wire in order to read codes off your check engine light. i want to know which pin number on the ecu to jump because my is a obd0 converted to obd1. meaning i have a adapter to convert 0bd0 to 0bd1 and all the wire is green. thank you for you advice.
    Titties!!!
    there is a blue 2 pin service connector under the passenger side kick panel/ dash that you jump. the blue connector may be in a little holder under there if you don't see it immediately. then the check engine light will flash and you count the blinks. is it has a slow then fast blink it is a 2 digit code. here is pics and locations of the connectors.
    http://alflash.com.ua/honda.htm
    West palm beach
    what she said ^^google is your friend...
    NO ADVERTISING
    -IA MANAGEMENT
    it is a ef 89 civic si so i don't see the blue service connector and the check engine light don't flash. check engine light is on but won't flash for codes
    Quote Originally Posted by preferredduck View Post
    still don't see the harness and check engine light don't blink.
    PURP-a-trader PURP's Avatar
    Quote Originally Posted by jdmalltheway View Post
    Then you're doing it wrong.
    Here, this should help.
    http://www.importatlanta.com/forums/...-READ-FIRST***
