Ok guys. I been puzzled by this for hours now. I been workin on my friends car. 95 hatch with a LS turbo. It sputters in high rpm
tuned ecu (for this setup)
dsm injectors
walbro 255
new fuel filter
new distributor cap
new rotor button
new coil
new wires
new plugs(tapped at 26)
new map sensor
all vacuam lines checked
timing is spot on
I drive the car and it sputters above 5000 I retard the timing and it gets worse so I advance it fully. It runs better but still sputters. I pull it in and it sounds like a misfire. I check the plugs. They are fine I make sure the wires were on good, they were fine. So I pull the plug wires off one at time and realize that cylinder 2 doesn't change. I feel the injectors and one feels different. I loosen the rail and remove said injector for cleaning. I look into the top and it has a lil dirt in it but nothin that should clog it. I spray it with parts cleaner to blow out as much as I can, it comes almost completely clean. Put it back in and it has the same skip but doesn't feel as bad
I have notice that the car doesn't seem to sputter as bad with the timing fully advanced, but this goes against ally better judgement
I guess my question would be do you think it's the injector or could it be the ignitor has a bad spot in it. Please helpe out
<<<BOOST
