Results 1 to 13 of 13
Thread: #3 cyl. not firing!
    AEM_integra
    macon
    Default #3 cyl. not firing!
    alright i swap my head out on my 97ls integra. cuz i jumped timing about 3 months ago and thought i had a bent vavle and i did, Swap went fine new. head gasket and the head i put on was running on my friends car . has 1500 miles on the rebuild. we adjusted the vavles while we were at it. get everything on start it up and #3 cyl not firing. not the wire not the spark plug. sounds like shit and skips like hell.
    i know i need to do a compression test and check my timing but has anyone ever had this problem?
    would timing make only one cyl. not fire?
    lmk reps for good advice
    West palm beach
    are you getting fire to the plug ?
    NO ADVERTISING
    -IA MANAGEMENT
    Senior Member WalkS's Avatar
    Middle Ga
    Check your distributor cap, look at the terminal for the number 3 cyl.
    Pull the spark plug wire while the car is running, arch it against the vc to see the spark. You should be able to hear it without arching it. Also listen to the idle when you pull the wire and plug it back in. If the idle stays the same when taking it off and putting it on, you might have a dead cylinder. (If you have spark to the wire)
    I am in the same position with my CRX, a compression test will verify it all. Do the test and see what the result are...
    JJSPEC Racing
    AEM_integra
    macon
    i told yall i check the wires and plugs and i know its getting spark. doing a compression test tomorrow and update tomorrow
    West palm beach
    if your getting fire, it's either compression ( bent valve ect. ) or fuel injector issues....
    NO ADVERTISING
    -IA MANAGEMENT
    AEM_integra
    macon
    gettinmg fuel in cyl.
    im thinking its the valves.
    guess the head wasnt as good as he though...
    but i have 2 spare head i can take the valves from.
    but will give compression results in the morn
    double check your valve clearance. If you adjusted it too tight they could be open.
    lol if you have fire,fuel... you just need to come to terms w/ yourself and figure out why the comp is down.
    AEM_integra
    macon
    looks like the heads coming back off....
    AEM_integra
    macon
    i would make sure the valves in that cyl are properly adjusted before i went through the trouble.
    AEM_integra
    macon
    i did and actually made it to loose just to make sure. heads halfway off but i been sick for the past 2 days and dont feel like working on it anymore today. but hopefully tomorrow it will be off and ill give a update
    AEM_integra
    macon
    ugh did work even though i feel like shit and found out it did have a bent valve cant tell till i stuck my .005 feeler gauge in there and it slid right in.. guess the head wasnt as good as he though... but shes up and running now.. close thread and reps for the help.
