Results 1 to 14 of 14
Thread: d series won't hit 7200 rpm
    Post d series won't hit 7200 rpm
    I didn't have any spark so i switch out the whole internal distributor from a 1.5 dx obd1 to my obd1 1.6 si distributor. if the car is just in neutral i could rev to 7200 rpm but if i drive it and step on it, it won't go more than 5200 rpm. it seem like it want to go over it but then it get kick back under 5200 rpm like a rev limiter. i need major help cause that is where all the power is.
    turbos
    what engine are you working with???
    TOO BIG
    d16z6 single cam vtec
    DAMN NO ONE DON'T WANT TO HELP. COME ON I NEED HELP REALLY BAD. I AM NEW TO THIS.
    this just happened to my friends car. any CEL's? did vtec work before? check to see if theres a code even though its not showing
    GWINNETT IS GREAT!
    limp mode?
    so basically youre using the wrong ecu?
    what?
    idk man
    McDonough
    Sounds like limp mode.
    Bitches love bacon.
    yea vtec was working but i haven't check the codes yet.
    limp mode?
    what?
    idk man
    using the right ecu. p28
    Quote Originally Posted by Street Expansion Inc View Post
    yes vtec was working properly
    IA Member Engineernik's Avatar
    Jun 2012
    Snellville
    i have the same prob but i hit 6000 rpms and sometime when im in 4th hittin 4000 my eng light cuts on and when i cut the car off the lights goes as well
    Quote Originally Posted by Engineernik View Post
    Please read post dates before replying! Theres no sense in bumping a useless thread that died over 2 years ago.
    this thread been dead already but after a couple weeks the distributor crack on me so i guess one of the wires had a cut in it or else something wasn't acting right in the distributor and cause high voltage to melt my rotor inside of it and crack the cover of the dizzy and replaced my dizzy and redo my timing just incase it had jump a tooth and now the car is running fine...only problem is still have a cell for vtec n speed sensor but because i'm using a cable tranny and the speedometer cable is worn out where it connect to the cluster.
