Thread: d15 atuo to manual swap questions
    Certified Gearhead bigbadjohn07's Avatar
    centre,al
    Question d15 atuo to manual swap questions
    i recently bought a 95 eg and it came stock with a d15b automatic in it and im wanting to do a manual conversion to it and im wondering what all i need to do this other than the clutch, manual guage cluster, tranny, and manual center console if anything else is needed please list it below
    reps for help
    Senior Member Patterson's Avatar
    Summerville
    Tranny
    Tranny Mount
    Shift linkage
    Shifter
    Fly wheel
    Clutch & Pressure Plate
    Clutch line
    Master cyl
    Gas-Brake pedal assy
    Clutch petal assy
    Center Console
    M/T ECU
    I'm thinking you will need axles but not sure if they will change out.
    You also don't HAVE to have a cluster unless you just want the P-R-N-D-L off the cluster.
    Hope this helps and if i missed anything someone i'm sure can chime in.
    barrow county
    auto and manual has different tranny mount
    d series shift linkage
    clutch master cylinder ( i dont think you need if using cable tranny )
    pedal assembly
    you dont need center console ( only for looks ) you can tap the auto shifter out and poke manual shift in
    best way is to find a civic in the junk yard and transfer everything over, take away having to shop for every single thing, from bolts to plastic parts
    gl with swap, im keeping my ex auto + boosted and in couple of months find a eg hatch and boost it
    Summerville
    ^ hey have you looked at TCI stuff for an auto tranny? looks like it would be fun to play with one on boost
    barrow county
    dont worry, i researched enough before boosting the auto tranny
    5 pound looking at around 150-170. waiting for this thing to start slipping and time to swap
    who buy d series auto tranny?? this is my rout
    centre,al
    i have a eg hatch and i hate that it's automatic idk im just wanting to do the swap and turbo it but i might wanna do a head swap any idea what heads would match up to the d15 im not use the d15 i use to have a 98 dx which had the y7 in it and i did a y8 head swap on it
    barrow county
    any d series head will work on it, just like the b series
    try zc head, im not sure if the dohc zc will work on it but a sohc zc will for sure
    swaping to 5sp is going to run you atleast a grand
    easiest is to find one in the junk yard, may cost less if the junk yard is cheap
    if you by parts by parts it'll cost way more
    barrow county
    oh stay away from y8 head, its obd2
    obd2 head on a obd1 block is going to need a lot of conversion , stay with zc or z6 (zc is better)
    centre,al
    ok thanks man
