Results 1 to 40 of 40
Thread: Ecu Code Blinks (C.e.l)
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Ecu Code Blinks (C.e.l) UPDATEEE!!
    UPDATEEE!!!!
    Replaced the Engine Coolant Temperature & Intake Air Temperature Sensors today..CHECK ENGINE LIGHT IS OFF
    & cranks up on the first try also
    ONLY problem is that it still idless
    Idles alot too!!
    Ive replace idle air control valve & those two sensors i mention beforee
    What else could be going wrongggG???
    West palm beach
    NO ADVERTISING
    -IA MANAGEMENT
    code 10 and code 6 if i read the post right.
    6
    10
    Southside Ridin HATCH
    BOOM
    With Your Mom
    Thanks Guys!
    could those two be the reason its idling alot?
    code 10 yes..
    And for 6 you need to change the sensor anyways.. and if you have VTAK, That shit aint gonna be poppin!
    With Your Mom
    code 10 yes..
    Alright thankss..
    but where exactly are those two sensors located?
    and are they hard to take out
    ECT is on the Right side of the head...near coolant hoses ( It screws into the head)
    IAT is on your Intake mani.. 2 screws that hold this sensor in..
    What engine?
    wrong thread
    With Your Mom
    What engine?
    d15 sohc
    we take payment layaway foodstamp and trades
    With Your Mom
    What engine?
    d15 sohc
    confirm harness grounds at thermostat housing- common denominator for multiple codes.
    With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion. - Steven Weinberg
    With Your Mom
    Quote Originally Posted by bam-bam View Post
    He saying.. Make sure the engine grounds are grounded...
    the Tranny, VC, and Thermo. housing....
    With Your Mom
    double check and seems to bee good.
    With Your Mom
    UPDATE!!
    Bought Engine Coolant Temperature & Intake Air Temperature Sensor's
    everthing seems to be finee.. only problem is that the E.C.T.S plug was put on der with silicon and the cables were pealed.. so they riped.. the cables are still there so tomorrow ill go to the junk yard & get the plug for that sensor & oncee on..ill check if c.e.l still comes on!
    Thanks Guys
    With Your Mom
    up
    So it just has bad idle now? no light on?
    With Your Mom
    yuppp..juss idless.. another question.. if the check engine light is off.. should the ecu still keep blinking ???
    Idles? LOW TO HIGH... or just REVS HIGH or what man??? IF you have some Throttle body cleaner.. Spray that around all your Intake and throttle body gaskets... you possibly have a Vac leak... Spray it around the gaskets if the IDLE goes down or Choaks then replace that gasket(it has a whole or leak)
    your ecu is still blinking the codes?
    With Your Mom
    yeah idles from low to high.over and over. ..
    & yes the ecu keeps blinking and more than 6timess this time
    Sounds like the VAC leak...
    Have you disconnected your neg battery terminal.. to RESET your ecu..
    What is the ECU blinking? exact number? thats your codes..
    With Your Mom
    10 & 16 quick blinks..
    could the vac leak be that the coolant sensor isnt screwed all the way in?
    Code 10 IAT
    code 16 Fuel injector..
    Vac leak isnt going to come from the Coolant temp... Coolant would just leak out of there.. well that is some sort of leak, but NOT it..
    Do the throttle body cleaner trick.. and reset the ecu by taking Negative off the battery for a min...
    If the codes are still flashing.. let me know...
    Quote Originally Posted by geezy View Post
    i think u are reading it wrong. it wouldnt do 10 or 16 quick blinds it would do 1 long and 1 long 6 quick
    ^^^^^ very tue, i forgot bout that!
    With Your Mom
    you think a injector cleaner will fix the injector problem or they need to be fully replaced?
    With Your Mom
    Sea foam wont FIX many problems really... Its just a "cleaning" agent..
    From your PM.. It sounds to me that you are, stressing to hard over the idle... you said it fine one minute, then shitty the next?
    THER IS ONLY SO MUCH ONE CAN TELL YOU OVER THE NET, THIS IS WERE YOU PAY FOR SOMEONE TO LOOK AT IT...
    gl
    gl
    qft there is only so much people who dont have the car can do.
    Hamilton, GA
    So what's going on with this thing now?
    Is your Fast idle valve screw tightened or do you have one?
    What he's saying with the brake cleaner is to:
    1.crank it up
    2. Spray some brake cleaner/throttle cleaner on the intake gasket, throttle body gasket area. And see if the idle goes to normal if it does then whichever gasket is bad or something else in that area has a vacuum leak.
    Actually had to do it today on a V6 intake at work. Had a fluctuating idle so I had to take the intake back off and clean the gaskets. Put it back together and was fine after that.
    With Your Mom
    gl
    is not that im stressing. is dat been having this problem for so long and it still comes back ... if it contines on tomorrow.. im taking it to a shop!
    Quote Originally Posted by T2KU View Post
    1.crank it up
    ill make sure to try that!! thnxx
    With Your Mom
    UPDATED
    Im 95% sure,the problem is Fixxed
    It Was a Vacuum Leakk....
    YYYYYYYYYYYYYYYYYYYYYAAAAAAAAAAAAAAAAAAAYYYYYYYYYY YYYYYYYYYYYYYYYYYYY
    thank god
    Hamilton, GA
    Hahahahaha. Glad to hear it dude. You need to get barefoot and black4drek a sandwich. Lol
    With Your Mom
    thank god
    How about a round of Beers!!!
    My stress & depression is over ha
    im tellign yah
    Titties!!!
    6
    10
    he also got a code 16 that he pmed me and that was fuel injectors. i have met him and he has some parts from my old hatch and i offered to read the codes.
    Titties!!!
    hey if it needs adjusting, anything head my way with the hatch you have there are certain things that will and won't work i know exactly what you have and i had the same thing, still have all injectors, sensors etc but i know for a fact the idle can be tricky if you don't know the systems. i learned this the hard way. hey you need to come get this cam from me so you will be a little faster and get better mpg in the city.
