Results 1 to 19 of 19
Thread: B16A head on a crv bottom end.. will it work?
    Oct 2009
    Warner Robins, GA
    Default B16A head on a crv bottom end.. will it work?
    thinking of mounting a B16A head on a crv bottom end. What do i need to know before i start this project and is it a good combo?
    Southside Ridin HATCH
    Yea it will work
    its a standard swap theses days. search for lsvtec on google.
    Oct 2009
    Warner Robins, GA
    Ive also heard with this swap, it is a pain in the a** to get aftermarket cams to time correctly. is there any truth to that?
    Northwest Georgia
    no there is no truth to that, its the same thing as an lsvtec and i use big cams on my lsvtec. Only reason big cams wont time correctly is if the head is shaved down a ton, and that goes for any cam.
    Oct 2009
    Warner Robins, GA
    right on. Thanks for the info guys, im sure I will have more questions as the build starts
    GET It Ima HUSTLER youngmill's Avatar
    Some Where Gettin Money And My Women Be BAD. TalkIN Dollar Signs! I know You Heard About It.
    It sure is a good combo...well if its done right...
    Parts NEEDED:
    GOLDEN EAGLE LS/VTEC KIT 84MM IF YOUR NOT GONNA BORE OUT THE BOTTOM END OR UPGRADE THE PISTONS...STOCK :GOODJOB:
    ARP GSR HEAD STUDS
    HEAD RESURFACED
    VTEC ECU
    VTEC WIRING HARNESS
    VTEC SPARK PLUGS
    B16 SPARK PLUG WIRES
    KNOCK SENSOR OR CHIPPED ECU WITH KNOCK SENSOR DELETED
    NEW OIL
    COOLANT
    YOU CAN USE THE WATER PUMP FROM THE B20
    YOU CAN USE THE OIL PUMP ALSO NO NEED TO CHANGE THEM UNLESS THEY ARE READY GOING BAD, THEN IT WOULD BE A GOOD IDEA TO CHANGE THEM BEFORE YOU GET DONE WITH YOUR SWAP.
    IF YOUR PUTTING THE SWAP IN A NON VTEC CAR, YOU WILL NEED TO WIRE UP THE VTEC AND THE KNOCK SENSOR. EITHER TTHE RIGHT WAY OR THROUGH THE ECU
    THATS PRETTY MUCH IT...
    Northwest Georgia
    do yourself a favor and use golden eagle head studs, not arp.
    Im done with arp lol
    CA Driver OldSchool87's Avatar
    Forest Park
    Use the GSR head not the B16 Head. The B16 CC Volume is 42.70 CC's and the GSR CC Volume is 41.60 meaning higher compression from the start.
    B16/B20 lsvtec 9.1:1 approx.
    B18/B20 lsvtec 9.3:1 approx.
    I have a Turd in my pocket.
    Forest Park
    to answer your question 98blackcivic they flow virtually the same. they both have 28mm exhaust valves and 33mm intake valves. so the difference in flow is going to be in the B16 mani VS the GSR mani and also port matching. to got the most power out of the B16 Honda cast it as close as the could so that it would flow good. they did not focus on this with the GSR being that its a larger displacement engine and did not require such
    If you port match a GSR Head and run a skunk2 mani on a B20 block. VS a B16 port matched with a skunk2 mani on a B20 block I willing to bet the GSR head would give more power.
    Norcross
    i thought you're suppose to use a gsr oil pump?
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    Quote Originally Posted by j0nbunklah0m View Post
    Yea any b series vtec oil pump will work. They pump more oil to the head than a non vtec oil pump
    b20b is in!!!!
    b20b vtec coming real soon!!!
    Forest Park
    Yes you are right sir......but......I'm Just comparing heads.
    Forest Park
    Quote Originally Posted by james497 View Post
    wait i miss read this.. any OBD2(96 and up) B-series will work. they are all the same, Vtec or Non
    Quote Originally Posted by OldSchool87 View Post
    correct...it has to be with in the years...0bd2 all same...0bd1 all the same...they all do the same thing...no need to change oil pump and water pump... just do the basics...gsr head is better than a b16 head...the diff is the combustion chambers...
    Texas
    No OBD 1 is very slightly different.(different part number) OBD 2 are all the same, and even the B20 oil pump is the same as the 96^ oil pumps.
    My sources ( I work in Parts at Acura)
    Forest Park
    Quote Originally Posted by SoLJames95 View Post
    yeah thats what we are saying "OBD1(92-95) has 1 part#" and "OBD2(96-up) has another part#" not that they all have the same, just the same within their emmission code regardless of Vtec or non
    EF'N dirtragz's Avatar
    Jul 2009
    the ham
    Quote Originally Posted by youngmill View Post
    Parts NEEDED:
    ARP GSR HEAD STUDS
    HEAD RESURFACED
    VTEC ECU
    VTEC WIRING HARNESS
    VTEC SPARK PLUGS
    NEW OIL
    COOLANT
    x2 and dont forget to remove the oil squirter in the block
    88 crx hf lsvtec 153hp 117tq mainstream
    You always lose money chasin' hoes, but you never lose hoes chasin' money.
    Quote Originally Posted by Civichatch91 View Post
    I will never cheap out again...I should have known better
    Southside
    holy hell I've been gone for way toooo long wtf
