Results 1 to 3 of 3
Thread: ANYONE USE STEAM???????????? Other suggestions
    Feb 2010
    Carrollton, GA
    Default ANYONE USE STEAM???????????? Other suggestions
    IM fed up with dealing with dirty parts all the time and want to find something that'll really cut through grease and grime. Granted my stuff is older (probably dirtier) than most's on here, but suggestions will be helpful. Ive tried every degreaser known to man, so im looking at other means. I know steam can cause problems with electrical systems sometimes when used under the hood, but does anyone use it? If so what unit are you using.
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    The best thing you can use with any degreaser is elbow grease. Seriously. If you just spray it on and rinse it off, you won't get the results you want. Scrub that shit. PM me and I'll do it for you.
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    Feb 2010
    Carrollton, GA
    Quote Originally Posted by XanRules View Post
    Dont worry, I do the elbow grease thing. I spent two hours with a wire wheel bit on a high speed drill last night knocking that stuff off my rear end I'll be putting in the skylark.ha I thought it would come off while I was sand blasting but it wouldnt. It was tough. Just looking for a time saver.
