Results 1 to 20 of 20
Thread: Layout of a truncated cone
    Default Layout of a truncated cone
    If someone can help me figure out the measurements here, I will happily rep them +28 every time I see them post and I can rep.
    http://mathcentral.uregina.ca/QQ/dat....06/phil1.html
    My measurements known are (labelled according to the diagram in the link):
    * t = 2.5" diameter
    * b = 4" diameter
    * w = 14"
    I've worked it out, but I'm 90% sure I'm messing up somewhere.
    I've gotten:
    r = 7.799
    R = 12.559
    Inner circle = 57 degrees
    Just doesn't make sense considering those numbers are pretty much the same as the circumferences.
    ホンダ・インテグラ allout13's Avatar
    Dec 2008
    Cartersville
    * t = 2.5" diameter
    * b = 4" diameter
    * w = 14"
    I've gotten:
    r = 7.799
    R = 12.559
    Im confused...
    radius should be half the diameter so...
    r=1.25"
    R=2"
    or am I misunderstanding something?
    Quote Originally Posted by allout13 View Post
    Im confused...
    r=1.25"
    R=2"
    If you were making a 2.5" cylinder and a 4" cylinder, you'd be correct, but when you're doing a truncated cone unfolded, the length of the cone and difference in diameter, changes the arc radius of the arc length that forms the circumference once the shape is rolled into the truncated cone.
    GWINNETT IS GREAT!
    id help but my mind is fried after doing about 100 derivative problems...my minds taking derivatives upon derivatives out of normal things isee around me
    Dec 2008
    Cartersville
    ahhhh
    Im getting r=23.333333 R=37.333333
    inner circle is 19.29 degrees
    according to the page: the outside radius R is simply w more than the inside radius r so the answer you got appears to be way off.
    ahhhh
    Im getting r=23.333333 R=37.333333 Im not sure how accurate this is, but I'll rework it
    *EDIT** I guess I quoted you as you edited your post, LOL
    Those numbers look right, actually!
    __________________________________________________ __________________________________________________
    Roll a piece of paper into a cone, cut the ends off so they sit flat when it's set down on a table or something. Cut the cone down the length of the "height", so that it unfolds like the diagrams on the length. I think you'll understand it a little better.
    The radii of the two diameters created, won't be the radii used if you were making two seperate cylinders that didn't taper.
    The two radii will be a number bigger than any measurement given, as the length isn't short compared to the taper. If that makes sense.
    Dec 2008
    Cartersville
    I may be way off, but Im bored as fuck. lol
    here's my work
    That all looks great. I'll check it out when I get a chance to lay it out on a poster board. Better than the numbers I kept getting
    Thanks man!
    Dec 2008
    Cartersville
    Thanks man!
    no problem!
    The answer you gave worked perfectly! Thanks again, bro.
    I'm Glad I'm Human CHRISNITTOLO's Avatar
    Oct 2009
    Stockbridge? Ellenwood?
    You're welcome.
    Quote Originally Posted by tdurr View Post
    sigged.
    Middle, Ga
    Learn math, Evan... dumbass. lol.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Quote Originally Posted by NVM View Post
    You couldn't scratch your ass hard enough to figure out 4 is the answer to 2+2.
    Middle, Ga
    How cute... did you think of that yourself? I mean, just hard to believe seeing as how you can't do 4th grade math. lol.
    "Damn, Its Tyler"
    Sorry I was frustrated after trying a few different layouts from my teacher that didn't work? Last I checked, you didn't give an answer, so you have no room to talk.
    Oct 2009
    I could. But it wouldn't make much since to do so.
    sigged.
    Middle, Ga
    I'm too cool for math. Would have gave you an answer but you can't understand this so you couldn't understand my answer. See what I did thar.
    "Damn, Its Tyler"
    Middle, Ga
    Evan, BTW repped, cause you're that much of a smartass/ lol
    "Damn, Its Tyler"
    I see you're also too cool for proper grammar.
    Oct 2009
    I'm about to fucking reply to all the threads with my face if I don't get off and go to sleep. Goodnight, guys.
    sigged.
