Results 1 to 10 of 10
Thread: 95 civic tie rod
    JDM-EJ1 shadowx3's Avatar
    G-County
    Default 95 civic tie rod
    am planning on changing my civic tie rod and onces i change it do i have to get an alignment on the car?
    LAWRENCEVILLE
    yes
    Hella stock member!
    G-County
    what happens if i dnt?
    Southside Ridin HATCH
    Tie rod end?
    You can "mark" were the thread, was then take it off... Then replace and screw on to same spot..(your mark)
    G-County
    yes tie rod end and what you mean?
    Get some Marker or something of that nature..
    Before loosening the Nut for the tie rod end.. Mark the position of it...
    Unscrew the Tie rod end off... Screw the New one on until you get to your "set" mark.....
    This way your Toe wont be out of line too much...
    South Side Georgia
    I changed both tie rods and my car rides like shit.. I strongly recommend to get a alignment... Only $40-50... G/L
    resize pic
    G-County
    ok thanks bro
    barrow county
    if you do it right you dont need a alignment
    like black4drek said, mark where the old tie rod end was and screw it to the same spot on the new tie rod was. count the bumps ( w/e you call them).
    if you really fail at counting than take it for a alignment and they'll count for you and charge 50 buckx
    Quote Originally Posted by blue_gt View Post
    lol doing it right is getting an alignment when done.
