Results 1 to 10 of 10
Thread: compression test results
    92 Hatch redneckhatch's Avatar
    White Castle
    Default compression test results
    I bought a b18b the other day. So today I did a compression test and I got these readings.
    I had to do the test with the engine cold so I know that can effect the readings.
    1-95
    2-155
    3-155
    4-90
    Just need some ideas of what this could mean
    barrow county
    does it smoke?
    probably compression rings or bent/burnt valve
    White Castle
    Quote Originally Posted by blue_gt View Post
    does it smoke?
    I don't know if it smokes because its not in my car. I did the test with the engine out of the car.
    ^^this guy loves you jdm-civic's Avatar
    the sky
    put some oil in the cylinders before you do it again, and if the numbers go up, then its bad rings
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    White Castle
    Quote Originally Posted by jdm-civic View Post
    And what if the numbers stay the same what could that mean.
    bad rings or fucked up walls
    WEST_SIDE
    just my e cents on a whime, since its 1-4 at some point the pistons have kissed the valves? Maybe if u do a CLT u will get a more definite answer.
    with those numbers the engine will definitely run, if it runs good or not is a gamble. ive done compression tests where one minute its low and the next is high
    White Castle
    Ok thanks for all the replays here in the next few days I going to take apart the engine and look everything over. If I find anything ill post it up.
    Turbo City USA
    Seems low in all the cylinders. My LS (B18B1) is around 180ish on all 4. I would check timing first to see if the Belt has slipped a tooth or two.
