Results 1 to 23 of 23
Thread: honda problem!!!!
    ^^this guy loves you jdm-civic's Avatar
    the sky
    Default honda problem!!!!
    ok, the car is a 91 civic with a jdm b16 swap, pr3 ecu and everything is wired correctly and no c.e.l.'s. the problem is, while driving long distances at a steady rpm, the car will start losing power and bucking like it isnt getting fuel if i keerp the throttle in the same position but when i give it gas it will jump to regular power and feel normal untill i let off and return to a stable position, it will do it again. ive found a solution is while the car is still in gear turn it off then turn it back on and that will fix the problem for like another 20 mins but then it will start again untill i turn the key on and off again. what could the problem be?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    the sky
    anyone?
    the sky
    help=reps
    im down right fierce hadouken's Avatar
    maybe the vtec solenoid. or maybe a dirty maf
    McDonough
    Quote Originally Posted by hadouken View Post
    can't see a vtec solenoid causing that but weirder things have happened...i would look into a fuel issue.
    Bitches love bacon.
    maybe a really clogged fuel filter, could be a bad O2 maybe? You got any codes?
    My line of work
    www.internationaljets.com
    McDonough
    He stated no CELs but I was thinking the same thing too. Fuel pump intermittently cutting out?
    Bitches love bacon.
    Certified Gearhead RHD_Joe's Avatar
    I've had somewhat of the same problem before. Try this disconect your O2 sensor and drive it and see if your problem continues..If the problem stops oviously replace the O2. Also are you running 2 O2 sensors or just one? If that doesn't make the problem stop then maybe you have a bad dizzy or fuel pump.
    PG+K
    your right hand man 97_luder's Avatar
    check your fuel filter, my aunt had the same problem with her accord and she replaced it and the problem went away
    the sky
    yeah no check engine codes and it has a brand new fuel filter on it. i think i might try to disconnect the 02 and see if that changes anything, btw it has 2 o2 sensors and its a obd0 crx si harness
    the sky
    and if it help, it had a knock sensor code last week but who ever swapped the motor didnt wire it into the ecu and i rewired it but the problem still happens
    McDonough
    is your CEL even working?
    Bitches love bacon.
    barrow county
    KINGZOFSOUTHTOWN
    Norcross
    MAFS are for Nissans, MAP sensors are for HONDA , so check ur MAP
    Quote Originally Posted by SVTsanctuary View Post
    x2, if its any O2 sensors or anything im sure your CEL light would come up.
    -hmgdrfter-
    PP TRACK 350Z
    the sky
    yes my cel is working and functional
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    check tha tps sensor i had tha same problem late throttle response
    b20b is in!!!!
    b20b vtec coming real soon!!!
    the sky
    hooked a dmm to it and it read fine.........
    Titties!!!
    Quote Originally Posted by 97_luder View Post
    agreed, sounds like a fuel or maybe MAP problem. on my si the MAP sensor hole was covered by a home made gasket and it would stall going down the road and never throw a cel except for random O2 CEL's. also i thought most obd-0 cars only had the one o2 seonsor like a 1 wire or something. i don't know about the si harness.
    driveslow skeet's Avatar
    Oct 2009
    Peachtree City
    sounds like a fuel pump problem to me. check wiring and all that good mess. also check the pcv valve and what not.
    -Derick-
    2007 - Si
    Hobos are people too! NinjaHobo's Avatar
    Norcross, GA
    check your MAP.
    ...I dream of going fast...
    vanilla sky.
    dam i had this same problem last week cause i put middle grade gas in my hot rod,when i put premium in it again problem solved.this is a tru story bro.
    the sky
    it has no pcv, just a breather filter, and all i use is shell 93 octane.
    Jun 2009
    Hawkinsville Ga.
    check your tps. mine did the same thing!
