Results 1 to 17 of 17
Thread: Bad Brakes!!!! Need YOUR Opinion!
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Bad Brakes!!!! Need YOUR Opinion!
    Just need your opinion!
    Ok So When i bought my car. it needed for it to be bleeded..so once i had a change i did that and the pedal still almost hit the floor ,giving me very little brakes and ive bleed them like 4times & still seems the same
    i know for a fact there a Leak In The rear cylinders (which im fixing this wkend) hope it helps!
    But could it be that the rotors and pads need to be replaced?
    N/A POWAH! Gorilla Eg!'s Avatar
    TAKE YOUR CAR TO MY BOYS SHOP.....Honda/Acura specialist in jonesboro....ask for TOM HORNSBY, and tell him Daniel Turner sent you and to take care of you, and he will do just that..... store # is 770-603-9197
    Quote Originally Posted by Gorilla Eg! View Post
    smalls people still use the tom name drop. havent heard 1 of them in awhile.
    to the op before a diag can begin u need to have all leaks fixed and system completely bleed.
    its no name drop, he is a friend of mine who ***BUILT*** the hatch that you see in my sig, im not some poser who throws around names to look "cool", just trying to help a person in need
    if u say so
    if u say so
    I totally made it all up....I ordered it off ebay and ive never met tom....sheesh cant even try to help people these days without someone tryin to down you
    With Your Mom
    Ok Girls back to the op! ^^^
    so to bleed the system you need to usually pump the brake like 4times.hold it in and open the bolt right...
    so ive done it over 4times & still seems the same!! ive even pumped it like 10times on each wheel & no resultsS!
    Quote Originally Posted by geezy View Post
    FIX YOUR LEAK
    With Your Mom
    FIX YOUR LEAK
    ill post my results after i fix the leak!
    thanks & reps
    barrow county
    l0l
    if it leaks air is getting in
    great way of wasting brake fluid, w/e you do dont get brake/power steering fluid on your paint
    With Your Mom
    hope ur fix your car my friend!....car problems are a pain in the ass....GL to you
    Mar 2010
    If you have leaky wheel cylinders, bleeding the brakes is borderline pointless...how much are wheel cylinders these days?
    Quote Originally Posted by Sir_Christopher View Post
    everyone knows vtec is a mate'n call
    WEST_SIDE
    So does it have a visual leak>? check for leaks by your brake booster.
    BTW My name is Tom
    With Your Mom
    Quote Originally Posted by SLow_POke View Post
    BTW My name is Tom
    Naa only the cylinders which ill be fixin tomorrow.. ill update ya as of tomorrow
    Scottish Scotsman's Avatar
    on the road to recovery
    BTW My name is Tom
    buhahahahahahahaha
    Quote Originally Posted by SlowEG9 View Post
    really cheap
    With Your Mom
    Quote Originally Posted by TheDrunkScotsman View Post
    really cheap
    yeah der like $8 a peice
