Thread: Part out!! B16A JDM parts, brand new aftermarket parts, B16A3 bottom end, tons!!!!!!!
    Oct 2009
    Warner Robins, GA
    Default Part out!! B16A JDM parts, brand new aftermarket parts, B16A3 bottom end, tons!!!!!!!
    I am parting out a B16A JDM motor build I started a long time ago but never finished.
    aftermarket parts are brand new, most I still have the boxes for and the JDM parts have under 20k on them. I also have a complete bottom end B16A3 out of a 1995 del sol v-tec. All prices are neg. but make sure your offer is reasonable please. I can and will sell a complete block and a complete head. Just lmk what you want on it so that we can negotiate a price. The best way to contact me is text 478-952-4027. I do accept paypal and can ship at your expense. I am willing to meet halfway to atlanta if your buying a good amount of items, in other words, Im not going halfway to atlanta to make $100 sale. Thanks for looking.
    Darton solid deck sleeves installed in block and block has been decked part# DS-B1681 $500 (with oil pump, oil pan, pick up tube, cap, girdle $550)
    Cometic head gasket part# CM-C4168HP (B16A or B18C) $50
    Venom adjustable cam gears part#VENC10-125B(90-99 TEG/99-00 CIV SI) $150 both
    B&M commando fuel pressure regulator $25
    Fuel pressure gauge $20
    Energy suspension motor mount inserts p# 16.1106R $25
    Holly 68mm throttle body 112-540 $180
    Unorthodox under drive pulley set UNR-040600902 $150
    Venom fuel injectors HP621-262 $150
    Air mass comp blue header $160
    Moroso oil pan 20901 w/ pick up tube 24011 $220
    Crower connecting rods (already attached to pistons) B93744B …………………………………… $500 (price is with pistons)
    Arias pistons w/ rings dome shape (were custom made bored .030 over from stock) part# 311855………….
    Venom intake manifold M21-333B $250
    Fuel cooler (6AN fitting) $20
    Installed inside the head and will be sold with head:
    Crower valve springs 68185
    Crower Titanium retainers 87093
    Manley valves custom made (11203-8 PC) valve head DIA: length 4.670 Tip .260, 5 angle valve job, port and polish, flow test, and assy…………………………….$700.
    -Stock parts: all have less than 20K on them and are JDM parts unless specified otherwise:
    Ecu with jet chip OBD2 $200
    Wiring harness OBD1 (off of 95 Del sol B16A3) $125
    Wiring harness OBD2 (lots of cut wires, could splice back and be used) $40
    Crank $75
    Cams and gears $75
    Valve cover $100 (can powder coat any color you want)
    Intake manifold $125
    Throttle body $25
    Fuel rail $20
    *IM, TB, and FR for $150
    Power steering pump $30
    (2)Flywheel $50
    Clutch (with good meat left, probably 75%) $40
    Honda OEM upper and lower engine gasket sets complete $make an offer$
    B16A3 complete bottom end minus oil pan (out of a 95 Del sol with 80k on it, not assembled) $make an offer$
    Stock clutch kit brand new in box (scahs) $130
    Attached Thumbnails Attached Thumbnails -block-jpg   -used-clutch-f-jpg   -venom-cam-gears-jpg   -venom-manifold-jpg   -valve-cover-jpg
    Oct 2009
    Warner Robins, GA
    more pics
    Attached Thumbnails Attached Thumbnails -pully-st-al-11-jpg   -obd2-harness-jpg   -oil-pan-jpg   -obd1-harness-jpg   -power-steering-p-jpg
    Oct 2009
    Warner Robins, GA
    more pics
    Attached Thumbnails Attached Thumbnails -new-stock-clutch-jpg   -motor-mounts-gu-9-jpg   -jdm-flywheel-jpg   -jdm-im-w-tb-jpg   -jdm-pistons-jpg
    Oct 2009
    Warner Robins, GA
    more
    Attached Thumbnails Attached Thumbnails -head1-jpg   -jdm-crank-jpg   -jdm-cams-jpg   -head-jpg   -head2-jpg
    Oct 2009
    Warner Robins, GA
    more
    Attached Thumbnails Attached Thumbnails -cometic-head-gask-jpg   -fuel-rail-jpg   -ecu-jpg   -air-mass-headers-jpg   -b16a3-block-jpg
    Oct 2009
    Warner Robins, GA
    last ones
    Attached Thumbnails Attached Thumbnails -aftermarket-pist-1-jpg   -block3-jpg   -block1-jpg
    Oct 2009
    Warner Robins, GA
    venom fuel rail and holley pressure regulator in the venom intake manifold picture are sold
    Oct 2009
    Warner Robins, GA
    ttt
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    bump gl nice shyt
    b20b is in!!!!
    b20b vtec coming real soon!!!
    M.O.B inutero93's Avatar
    valdosta ga
    how much for the head i did not see a price?
    valdosta ga
    ok i found the price im blind haha
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by inutero93 View Post
    Yeah its on there, if you have anymore questions just ask. Love your avtar pic btw! lmao
