Just put together my new system. Need some help with the amp settings to get this thing to bump.
1-12" Kicker L5(2ohm)
Hifonics Brutus 1200watt amp(1200x1ohm, 900x2ohm, 450x4ohm)
1.65.C.F, ported box.
As of now I have the sub wired to 1 ohm. The AMP manual says to match the headunit pre-out volts to the gain, My pre-out volts are 2v,so I turned my gain all the way up to 2v.
I have theres available settings;
Low pass:35hz-250hz
Subsonic:15hz-35hz
bass EQ:0-10db
phase:0-180degrees
