Results 1 to 4 of 4
Thread: LS automatic swap into automatic civic...question...
    Top Secret Build TopNotchEG9's Avatar
    45 min from the A
    Question LS automatic swap into automatic civic...question...
    I was wondering did anyone do a LS auto swap into a civic...I'm trying to figure out what else is needed...because I have the complete swap (motor, trans, mounts, axles, and ecu)...I also wonder is anything else missing...I'm doing this swap for my dad...thanks to anyone with the info...
    known as Charles
    The wiring is a nightmare and I won't suggest doing the swap. The civic auto trans is controlled by the ecu while the LS auto tranny has a TCM that is seperate. The wiring for the TCM in integrated in then entire chassis harness and would be very difficult to add to a civic. If you run the LS off the civic ecu it will only have 1-2 gears. This is for the OBD1 stuff but I am not sure on OBD2 stuff.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    barrow county
    if your already swaping over, might as well do 5spd swap
    chill six7teen's Avatar
    Columbus
    i believe the passenger side transmission mount is different as well. not 100% sure, but i think i remember it not fitting when i attempted this a while back..
