Thread: 87 mustang clutch??
    roberta
    Default 87 mustang clutch??
    ok well finally got this mustang runnin and today started it up in nuetral runs fine no leaks ect.i go to put it in gear and it will not go...i turned it off and ran threw the gears and all was good so i decided to start it in 1st and the bitch took off in my garage..lol.does anyone have an idea of what it might be.
    Stang Mod slostang's Avatar
    Southside
    cable?
    L'ville / Gwinnett
    Either the cable is adjusted all the way out and the clutch is never disengaging OR your pressure plate bolts aren't tight causing it to bind. I've had both of these happen on different Mustangs of different years... check your cable first and if thats not it then throw that sucker back on the lift.
    You need to reset the clutch quadrant. It is what the clutch cable attaches to, under the dash.
    roberta
    by the way its a 87,and how might i reset this
    Crawl under the dash and see where the cable attaches to the quadrant. The quadrant is two pieces with teeth, and one piece is spring loaded. If you look at it, you can figure it out. It should be yellow or tan color.
    Southside
    does it have an aftermarket quadrant? because if so it can't be reset.
    L'ville / Gwinnett
    Is it a stock plastic quad or an aftermarket aluminum one? Only the factory style can be adjusted. If you have an aftermarket quad you will need an adjustable cable or a firewall adjuster.
