Thread: One thing after another.....cooling system help
    Woodstock
    Default One thing after another.....cooling system help
    Ok here is the car and mods, don't think any of it will matter but.....
    98 Civic
    boosted b18b1
    forged internals
    t3/t4 turbo
    660cc
    255 lph
    tuned on chrome @ 11psi
    When I get on it, in higher RPM's under boost, my radiator hose starts to collapse and it forces coolant out from the rim of my radiator cap. My cap is brand new and is 16 lb cap. I was wondering if there was any way of fixing this, other than the metal hoses ($122 @ summit). If it matters it's a 1/2 sized radiator.
    eg6
    Apr 2009
    well id say get a thicker alum. one.
    Quote Originally Posted by Slomaro Z28 View Post
    98 Civic
    boosted b18b1
    forged internals
    t3/t4 turbo
    660cc
    255 lph
    steel braided is the only thing I know of. might be cheaper to buy some hose, and then the fittings seperate and make your own, but I'm not sure. Also check samco (?) hoses. I think they are reinforced.
    Woodstock
    Guess I should mention the hoses are brand new also
    Woodstock
    Well I fixed the problem, with a new aftermarket aluminum radiator. Guess it's not a bad thing to have a whole new cooling system.
    it's true! QD my fav tmracing83's Avatar
    Rockdale, GA
    True. Less worrying about overheating. You should be good
    OBAMA..... *IS*
    One. Big. Ass. Mistake. America.
    Woodstock
    Quote Originally Posted by tmracing83 View Post
    Yeah,
    16lb Cap= New
    Upper and Lower hoses=New
    Radiator=New
    Yeedeedee le se NovaScotia's Avatar
    modify a hose from an old smallblock chevy. they were spring loaded. there may be others but thats all i have off the top of my head.
    just read that you fixed the issue... the radiator causing it makes sense though.
