Results 1 to 31 of 31
Thread: Supercharger questions
    Out in the Boonies
    Default Supercharger questions
    1. Would super charging, say a k20, be the same as turbo charging a k20? As in going through the same process of upgrading rods/pistons etc. I understand you'd have to upgrade the fuel system and possibly ignition system, but would I have to worry about forged internals or anything of that nature?
    2. What cams would you be able to run on a supercharged motor? As in a mildly aggressive to a very aggressive profile.
    3. Is there a difference between turbo boost (psi) vs supercharger boost(psi)? (example 10psi on a turbo vs 10psi pulley)
    Jun 2009
    Phenix City, Alabama
    Yes, there is a difference between turbos and supercharges.
    Turbos will give you extremely more HP then a supercharger. If you are wanting a more reliable car I would suggest getting a supercharger. Turbos on the other are reliable if you do them correct, but I dont think not as reliable as a supercharger.
    Also, it doesnt matter what you are running 10lbs is 10lbs, turbo or supercharger. Although 10lbs on a turbo will probably give you more power then a SC.
    SC do have an advantage though. They are easy to install, I dont rreally know about price. I guess its all what you find and who you know. Also it all depends on how many lbs of boost you plan on running. If you plan on going over 8lbs I would suggest building the motor ( turbo or SC ), and if you plan on doing force induction I would suggest getting a fuel pump, injectors, ect.
    But like I said it all depends on which one you want and how many lbs of boost you are wanting to run. As for cams Im not really sure. I guessing getting turbo cams or something. Maybe someone else could answer that.
    Hope this helps man.
    unless you're going to get the newer jackson or something that you can run through an intercooler i would suggest turbo. roots type blower mounted directly to an intake manifold create a lot of heat and high iat kill power and motors over time depending on boost. also, increasing boost on a turbo is easier w/ a boost controller, vs. a s/c needs a different pully set to spin it more.
    you will need to upgrade the fuel system and go kpro to do either properly. tuning is the key.
    Northwest Georgia
    Quote Originally Posted by ej1boy95 View Post
    I just want to make one thing clear....this portion of the statement is 100% false.
    Quote Originally Posted by SPOOLIN View Post
    noobs talk in terms of lbs, l33ts talk in terms of CFM
    Supercharging id run no bigger than a "R" cam. Too big a cam and you will bleed boost off due to too much overlap.
    WIth a K20 id look into the Rotrex aka Kraftwerks superchargers, they are really nice and make as much power as a turbo.
    Benefits to supercharging (JRSC) is its cheap, good power, easy to install , no bov, no wg, no turbo manifold, no turbo etc
    Cons it only makes SO much power, it gets hot (no way to use an intercooler)
    Senior Member S2KJD's Avatar
    Quote Originally Posted by Nemesis View Post
    noobs make fun of other noobs rather than just helping by sharing the knowledge they contain
    Jul 2009
    superchargers will give you aids
    middle ga
    Quote Originally Posted by dallasb84 View Post
    Johns Creek
    What's that thing mounted in front of my radiator then? Last I checked it was a FMIC. With a centrifigual, you can use either an intercooler, or an aftercooler.
    well shit.....
    Ive got an SC with an intercooler....but maybe hes reffering to space and the designs of the available kits for that motor.
    Quote Originally Posted by David88vert View Post
    This guy has a Honda so in that context almost 99% of the jrsc on the market don't allow use of an intercooler.
    The only ones out for k series that use am intercooler are the rotrex kraftwerks ones.
    well shit.....
    Roots style superchargers for hondas for the most part don't allow use of an intercooler.
    He's asking about a k20 not a v8
    Out in the Boonies
    Thanks for all the response. I'm not looking to make big power. 300whp is plenty for me. I want more of a quick, low rpm response motor than a 600hp motor with major boost lag.
    With that in mind. Should I be looking into forged internals?
    I was also looking into a water/meth injection system. Good idea?
    Northwest Georgia
    You can always opt for the 900$ LHT Air/water aftercooler mod for the JRSC lol.
    Lasti checked they only do it for b series not k
    I know that, but even with a roots/tvs there should be some sort of heat exchanger. Seems dangerous to run any type of boost without cooling the charge coming in.
    Noob LOL
    JRSC never came with any intercooler so IATs do get hot. The comptech comes with an after cooler and now the new rotrex comes with an option for an intercooler
    pwned v8 boy
    this whole thread is blasphemy!!!!!!!!!
    And yes, I got pwn3d. My knowledge on Honduh performance stops at 20lbs of torque and durrrr vtec
    Jun 2009
    sorry for providing false statement. can u explain to me the true statement
    Jun 2009
    just because i used the terms LBS dosent mean Im a noob. It just means you have more knowledge in this subject then I do.
    Out in the Boonies
    Sorry if it is. Just wanted a little insight from people with experience before I decide which route to go. I'd rather do it the right way the first time than to double or triple what I spend the first time around.
    Northwest Georgia
    10 psi on a t3/t4 50mm is going to be in the range of 275 i guess on say a built b series....where 10 psi on a 72mm turbo is going to be 450 maybe. The bigger the turbo compressor, the more air its moving while its pressurizing the air....superchargers tend to be less efficient at moving air and generally don't flow near as much air.
    283.5°.516&quot;(13.11mm) DirtyMechanic's Avatar
    Alpharetta, Ga
    lol what?
    The G Spot Hero
    Northwest Georgia
    Quote Originally Posted by DirtyMechanic View Post
    lol what?
    Yes, take a turbo that same size as that supercharger and i guarantee there will be MORE overall flow.
    Is there science behind your picture or did you just feel like posting a picture of a hideous looking blower ....
    All bullshit aside, if you want to make BIG power, especially on a car that didnt have much to begin with, go turbo.
    Dont supercharge a car without some sort of after/intercooling, its stupid, especially in Georgia summers.
    I disagree. low boost you don't need an intercooler. Plenty of cars can run low boos pressure with no intercooler an be fine. It's about cylinder pressure and iat temps
    5psi=50-60whp with a jrsc non intercooler. A k20 supercharged civic hatch would rape almost any car on here stop light to stop light.
    If you go rotrex, you'll make the same power as a turbo setup without the high egt and iats
    rotrex k20 guys are making 400-450whp same as a full race kit.
    Alpharetta, Ga
    im just fucking around i know that size of the sc or turbo will depend on what psi and all that... it just matters how you going to use the power. turbo lag with high power for drag or maybe a nice smooth power curve for road racing. you need to find what your going to use it for.
    The G Spot Hero
    My thoughts exactly.
    Peek-a-boo mofucka what now?!
    Quote Originally Posted by DC2NR View Post
    All I have to say is, do your research. Know what power (HP, Trq) numbers you are looking at, then search for setup and prices. If a SC gives you the numbers you want then just go ahead and go with that, if a turbo makes enough for you to have fun then do that. Also look at install time and cost of install if you don't DIY.
    All I know is that a turbo might have more CFM and LBS compared to a belt driven SC. I think the belt creates to much of a drag on a engine as a turbo doesn't but then they both have there drawbacks as well.
    Out in the Boonies
    Quote Originally Posted by driftjunior View Post
    Thanks. Think I have all the info I need. As stated before I'm not looking for BIG power (300whp 240+tq is plenty). Just looking for a fun car to drive that'll respond when I want it to. I do have the DIY know how, I just wanted a little more in depth before I get into anything.
    Thanks all for the input and the 4-1-1.
