Results 1 to 15 of 15
Thread: catalytic converter problems
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    Default catalytic converter problems
    The other day i was driving and hit a pot hole hard,my car lost power and i pulled over looked under the car and the cat was red hot. The car won't start now does anyone know whats wrong? I think the cat is clogged.
    b20b is in!!!!
    b20b vtec coming real soon!!!
    GWINNETT IS GREAT!
    did you get the temperature readings on that cat?
    Jul 2009
    N. Philly
    naw i was on the side of the highway,but when i tried to start it i get a rattle in the exhaust,plus there was some white stuff in the end of the exhaust
    b20b is in!!!!
    Jul 2009
    N. Philly
    and after a while it started back up and pushed on the gas pedal but no power,and then it cut back off.
    b20b is in!!!!
    Jul 2009
    N. Philly
    damn nobody can help
    b20b is in!!!!
    Jul 2009
    N. Philly
    well answer me this will a clogged cat stop your car from starting?
    b20b is in!!!!
    Jul 2009
    N. Philly
    damn anyone ever had this problem
    b20b is in!!!!
    D owns B
    Nov 2009
    Augusta, GA
    Why don't you unbolt the cat from the header pipe and see if it helps? It's two bolts.... And yes a totally clogged cat can cause no start/low power.
    '94 EG Hatch, D16z6. Spec Stg. 1 Clutch.
    Plans are for some AUTO X
    Senior Member Patterson's Avatar
    Summerville
    Quote Originally Posted by BrandonR View Post
    X2 sounds like one or both bricks have busted and has stopped the flow. unbolt it and it should run.
    Jul 2009
    N. Philly
    thanks
    [QUOTE=Patterson]X2 sounds like one or both bricks have busted and has stopped the flow. unbolt it and it should run.[\QUOTE]thanks
    b20b is in!!!!
    As someone else say, sounds like there's some internal damage to the cat. Get it replaced.
    Apr 2009
    warner robins
    common sense would be to unbolt it
    your mom loves me
    Jul 2009
    N. Philly
    yea i know just double checking before i go pick it up from the wrecker
    b20b is in!!!!
    ding ding ding right answers
    Titties!!!
    depending on where you live and if an o2 sensor plugs into it, hollow it out and go, mine is hollowed out and i have it modified so i don't get a CEL, i know the tree huggers hate me but i couldn't find a high flow cat and a new one is really expensive.
