Results 1 to 18 of 18
Thread: Coupler keeps blowing off
    Default Coupler keeps blowing off
    The coupler on my cold side of my intercooler keeps blowing off at full boost. It's help on with a t bolt clamp, and its a straight coupler. I've tried tightening it down by hand as much as possible but it keeps happening.
    What else can I do to keep it on? anything?
    IA's bass guy
    Nov 2009
    paulding
    not that i know to much about general tech but when u tighten it down does it still have movement? do u try to see if its still loose?
    99 tahoe, build in progress
    ^^this guy loves you jdm-civic's Avatar
    the sky
    use two of the types you have to tighten with a flat head or a wrench......that shoild keep it on nice and tight. and make sure it not on the ridge and its fully seated as far back as possible
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Athens/Memphis
    I have read that the metal in the clamps can expand in high temperatures, effectively loosening and causing the coupler to blow off. I searched on google for high temperature resistant ones and found these:
    http://www.pdm-racing.com/products/hoses.html
    Look at the Kodiak Heavy Duty Spring Loaded Bolt Clamps.
    UGA: Everybody is laughing at us this year.
    Bead roll it, or flare the end of the piece of pipe w/ pliers so that it cant slide when tightened.
    this.
    Jul 2009
    try krazy glue...... it can glue a bowling ball to a cieling.
    Senior Member Patterson's Avatar
    Summerville
    Quote Originally Posted by dallasb84 View Post
    but really use something like a 3m spray glue (light coat) i've even seen people use hair spray. then tighten it down good and you shouldn't have a problem
    Where Am I
    Quote Originally Posted by Patterson View Post
    ^yep but sand the area down first too gives it a better surface to grab to... And If u still have a problem with hair spray use some gasket maker(permatex), but sand it first no matter what cause most pipes are chrome and smooth....
    YOURMOM tnomud's Avatar
    Coweta
    I have used hairspray. do not use 3M, it can get into piping and is needed on both surfaces, not just the pip. 3M has a hard time bonding to bellows
    Summerville
    Quote Originally Posted by tnomud View Post
    there you go. i've done one with 3m trim adhesive (gorilla snot) i just figured the spray would work.
    Lol. superglue..
    The pipe has a lip on it, but I may try to make it a bit more agressive so it will hold better.
    I'll also try the hairspray Idea. But my pipes are powder coated, not chrome silly. lol
    Light Tuned
    http://www.rgrayclamps.com/hdhoseclamps.htm it will work perfect for you very heavy duty I have personal exsperience with these clamps you can get these at truck parts stores or wherever
    Jul 2009
    i was joking......but.......nvm
    Feb 2010
    Bowersville,GA
    yep i am installing an intercooler now, I was told too that the ends need to be bead rolled. If it's just a piece of pipe it's going to slide right off
    im a organ donor :) 00 blk G20t's Avatar
    Nov 2009
    canton GA
    yup done the superglue thing one time going to the track with a DSM buddy. super glue worked for the whole day at the strip.
    Best G20 SR2009 convention
    in attendance Nissan national convention 2010(Omaha, Nebraska)
    top 20 hotlanta autofest 09
    the sky
    jb weld,zipties, and duct tape
