Results 1 to 18 of 18
Thread: !!!! EG CLUSTER HELP!!!!
    Southside Ridin HATCH
    Default !!!! EG CLUSTER HELP!!!!
    Ok soo My CLUSTER in EG chassis Civic Doesnt work.
    The back lights work. BUT NO RPM,MPH, Temp, gas, NOTHING WORKS.. ALSO BLINKERS WONT WORK WHEN I TRY THEM!!
    I wired the cluster CORRECT back to STOCK, It use to have a LS cluster in it that also DIDNT work..
    I ALSO swaped out a cluster from my friends civic, STILL NOTHING!!???
    Help needed asap.. thanks
    you sure your wiring is correct? You could have fried it so it wouldn't work in his car. Or just a bad cluster. The way to do it would be to use your buddy's cluster as the "control" test since it works. If it stops working after that, then you have problems and so does he lol. But if his works in yours and his again, then you have bad clusters.
    My line of work
    www.internationaljets.com
    Chickens Eat Eggs
    south side hoe
    damn, does your fuse keep blowing out?
    Chickens Eat Eggs
    south side hoe
    or did u check them yet?
    Quote Originally Posted by Starrfire View Post
    YES wired CORRECT..
    I put HIS cluster in MY car.. and it didnt work.. But when i put it back in his it works..MY cluster i have isnt bad.
    all my fuses are good
    Is there a Ground wire i need to hook up or something?..
    Maybe a loose pin?
    My line of work
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Are all your wiring harness connections....connected?
    check the copper layout where the plugs insert to the cluster. that happen to a buddy of mine. They may be scratched or plan Fuked up
    Apr 2009
    Villa Rica
    Good Luck bro, atleast you have cluster lights, I have to run with indiglo gauges in my ej because my cluster & dash lights don't work.... Bulbs are fine.... I believe I've got a loose connection because sometimes (rarely) they come on & work, then go out.... Either a loose ground, bad connection or switch is bad on mine, for now the indiglos work fine with me to see my rpm, mph, gas & temp gauges.... Bad part is my gas & temp don't work.... Plus my rpm & mph needles jump causing my mph needle to wrap around.... Just ghetto lol.... And a shitty cluster.... I need one asap.... Know anyone....?
    Quote Originally Posted by STRteg View Post
    Yea Im STUMPED! Think i might try to just get whole new harness for the inside of the car.
    Chickens Eat Eggs
    south side hoe
    man sound like the problem i had, cluster light and mph work,turning switch dont work for turning lights,reverse lights dont work,defrosser and fog lights dont work and seat belts....come by my house let me check it out!
    Oct 2008
    well if your gonna pull the dash to replace the dash harness you'll have more than enough chances and time to overlook all your wiring and make sure everything is up to par
    Duluth, GA
    Thank God I'm rollin' stock again. I hated bullshit problems like these.
    __DailyGrind
    just pull the dash. 30min fix or less
    I got this hatch like it is.. Somebody else F'd it up..
    Quote Originally Posted by i4_garage View Post
    I got no problem pullin a dash. pull the dash and do what? I have checked wires allready.. Probly juss gonna change out all harnesses
