Results 1 to 2 of 2
Thread: How to: Individual Coil Packs
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Default How to: Individual Coil Packs
    Has anyone converted to ICP (individual coil packs) before I always wanted to do the conversion but i haven't the slightest clue how. Can anybody help me with a DIY or a shop that can help me or even someone willing to do the conversion with me.
    reps will be given
    thanx in advance
    -SRK420a
    your moms house
    well if your engine doesn't have a factory crank angle sensor and a factory camshaft position sensor you need to get a good signal on both and then need to make sure the ecu will accept the type of signal your sending it i.e. wether it's a magnetic pickup or a optical sensor. but it's useless unless you have a standalone ecu to be able to adjust individual timing on each cly. and it might take a whole day on the dyno to pick up 4-5whp.
    unless you have a built setup your trying to extrac the most power out of possible it's not very cost effective for the amount of time and money it takes for the results.
