Results 1 to 21 of 21
Thread: Anyone around Stockbridge available to fix garage door openers
    'Round These Parts
    Default Anyone around Stockbridge available to fix garage door openers
    No sure what's wrong with mine but it went up and never came back down. You hear it running but it pulls nothing. Almost like it's stuck.
    Anyone?
    i'm in stockbridge close to Conyers by 155.
    I'll pay with Reps
    j/k I have some cash i can spot you with.
    Leisa and S. 4 Life NM?
    'Round These Parts
    No response yet?
    ummm Haiti?
    Quote Originally Posted by Kevykev View Post
    No response yet?
    ummm Haiti?
    lol earthquake!
    is it the motor making the noise? does it have a red rope you can pull in case of emergencies?
    Peek-a-boo mofucka what now?!
    A little town called Nunyagoddamnbusiness
    screw type or chain driven?
    Stang Mod slostang's Avatar
    Southside
    you're close to my store.
    'Round These Parts
    ^ What store?
    Chain driven Chris!
    Dj- Red rope pulled - I disconnected it.
    Motor makes noise like it's active but doesn't pull.
    GWINNETT IS GREAT!
    have you inspected it closely?
    'Round These Parts
    Yeah, the gear connected to the chain is still intact.
    I have not opened it though.
    Dec 2008
    Born n raised in the ATL
    Try just holding the button down.
    *looks out my window*
    Do it now!!! Someone's gonna come take that bike!! ooooo! can I have some of them storage continers, I need some!!
    If you can open the side and gain access to the sprocket. check to see if the shaft has a key (there will be a slot where a little rectangular piece of metal goes). If it is keyed make sure the key is still there. If it isnt keyed, hit the open button, and see if the shaft is spinning around inside the sprocket. If the shaft is turning and the sprocket is not, you need to tighten the set screws on the sprocket, there should be 2 about 90 degrees apart.
    'Round These Parts
    Quote Originally Posted by LizBiz View Post
    You got prollums.
    If you having girl prollums I feel bad fah you son.
    Quote Originally Posted by chrisdavis View Post
    Sounds like you need to come over here man. Damn mofo broke in down in detail... i'll be opening it up tomorrow - hopefully I don't get gottened.
    You got prollums.
    Im free around 2 if your home today, then you will be down to 98 problems.
    Senior Member G.C's Avatar
    Forgot
    can be many things. Check the easy stuff first.
    -Anything blocking the sensor...as dumb as it sounds, sometimes a random ass leaf or whatever blocks it.
    -Check the light on the sensor. See if its flickering/different color.
    -See if the chain is on the gear still. It can be slipping.
    -See if anything is causing the chain to be jammed or the gear.
    :idb:
    Pfft! ATLTSX's Avatar
    In a van down by the river
    Quote Originally Posted by G.C View Post
    What he said.
    You can also try pulling down on the garage door as you push the button. Maybe it just got caught up on something.
    Mainstream Performance
    'Round These Parts
    Just got back I'll om you my address maybe you can stop by tomorrow if you're free.
    Thanks yo!
    CHECK!
    Southside
    ^ What store?
    advance right there at the intersection of east lake.
    'Round These Parts
    ^ I'll come check you one day.
    Let me know when you run a special like 5qts of mobile 1 oil for $8 lol...wait NO REALLY!
    UPDATE:
    Garage fixed one of the gears were shredded (plastic drive gears to keep motor from burning out)
    3 hours of labor which would be 45minutes if i did it all over again.
    Garage is FIXED
    p.s
    OVERHEAD DOOR wanted to charge $400 to repair it.
    My repair cost: 17 (Gear kit) 12 (Pin Punch kit).
    Me being the MAN: priceless.
    Now I can fix like 80% of garage door openers since most are built the same.
    FUK IT! bowdown201's Avatar
    Next Door
    I think thats the same place that came and looked at our bay door at work. If so their a fuckin rip off. Bunch of damn rednecks
    it's true! QD my fav tmracing83's Avatar
    Rockdale, GA
    YELLOW PAGES.
    That simple.
    OBAMA..... *IS*
    One. Big. Ass. Mistake. America.
    In the land of the slow cars
    ahh
    'Round These Parts
    Quote Originally Posted by bowdown201 View Post
    It was $89 for labor and $3XX.00 for the part. I said "Thank you sir" hung up and started my own operation.
    Quote Originally Posted by tmracing83 View Post
    YELLOW PAGES.
    That simple.
    So you basically looked at the thread title ONLY before responding.
    selective reading causes that.
    Quote Originally Posted by stillaneon View Post
    ahh
    Yes my friend.
