Thread: h22 build
    Default h22 build
    what size turbo should i run i curently have an h22 g.e. sleaves wiesco 8.5 to 1 pistons an eagle rods stock crank the head is ported and polished with 2 mm oversize valves with b.c. stage 2 turbo cams i am running a precision 6176re ball bearing turbo with a peak boost mani
    i want to at least push 750
    i have all -10 fuel lines with an aero 1000 pump with a 10 ga. fuel cell
    may throw a direct port kit on
    eg k20-bb6-08 jk 5in lift on 37 krwlers
    Certified Gearhead 94ej2's Avatar
    Mobile, AL
    s372r
    kno where i could find one or possible trade mine << it is practically brand new like 500 miles
    you want to push 750 what? i hope not hp. if you know anything about the h22s they are the worse honda block to boost. you need to sleeve it to get any good power out of it.
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    Quote Originally Posted by blown_ss View Post
    psi obv
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    known as Charles
    He has Golden Eagle Sleeves. Chas the S372 will be enough for the power that you want. The compression is a little low so you will have to run a little higher boost. Just put a wet shot on it and see what it can do on the turbo you have.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    drives a family car
    Jan 2010
    In a plane
    Quote Originally Posted by cbfabwerks View Post
    g.e. sleaves
    and 750 on just boost will be hard, you should've gone 9:1 or a tad higher so you wont have to run stupid PSI. you'll need some spray and possibly water/meth to keep it somewhat safer.
    Soccer Mom Status
    AMF jnv255's Avatar
    Earth
    My car with the 372 made (sig). I'm hitting boost 4800-4900rpm, something like that. It would just light up my drag radials on the street, it was fun though.
    Follow us (JJspec racing) on Facebook
    http://www.facebook.com/pages/JJspec...876293?sk=wall
