Results 1 to 40 of 47
Thread: How to vent your valve cover
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Default How to vent your valve cover
    Why?
    When venting your valve cover, you help release pressure that is built up in your crankcase. Excess crankcase pressure can led to blow-by, seals popping, and a reduction in power. When doing LSVtecs/B20Vtecs and using an obd2 block, you loose the capability to release some of that crankcase pressure through the PCV system, and must make up for the lack of having one. You can release this pressure two ways, through the block or the head. I'm currently doing both.
    Parts needed for an AN Stainless Steel catch can setup.
    1-Catch Can
    This is the one I’m using (circled)
    It has two female ½ NPT fitting welding on the side, and one at the bottom for draining oil. (The fitting will depend on where you purchase the catch can from or what you decide to use if you made your own.) The inside must be baffle to allow the oil and flumes to separate.
    2- AN to Male NPT Adapter Fitting
    This part may not be applicable to every setup. I needed this because my catch can require I convert my ½ NPT fittings to –10AN fittings.
    (Part# SUM-220047 for red/blue, add B to the end for black)
    2-Weld-on Bungs
    I decide to use -10AN bungs on my valve cover
    Most people use -8AN, -10AN, or -12AN (there are people that use bigger ones, but I doubt they would apply to someone here). The rule of thumb, is the larger the better. Larger diameter bung would cause your catch can to less likely fill up with oil. Why? Because with larger bungs the velocity of the flumes is slower and less likely to carry oil with it. (Part# SUM-220063)
    Stainless Steel Line (length depends on the placement of your catch can)
    Order the lines based on what bungs you are using. I welded -10AN bungs on my valve cover, so I got -10AN SS lines. The length you need depends on where you’re placing the catch can. I order two 3ft lines (Part# SUM-230003)
    2-90degree bends
    Once again get 2 90degree bends based on your hose size. I’m using -10AN so I got -10AN 90degree bends. One end is going into the SS hose, and the other end will be screwed down to the bungs on the valve cover (Part# SUM-220087 for red/blue, add a B at the end for black)
    2- Hose Ends
    Once again get the hose ends based on your hose size. One side is going to the hoses, the other end is getting screwed on to Male NPT Adapter Fitting that I screwed into my catch can. (Part# SUM-220090 for red/blue, add a B at the end for black)
    Assembly
    To attach the bungs to your valve cover, you must strip the paint where the bungs go. Then you must “TIG” weld the bungs to the valve cover. Whatever location you weld your bungs to make sure you the OEM baffle is covering the area. Now drill holes, making sure you don’t drill through the baffle.
    Results
    To cut and attach the hose ends and 90degree bends, just mimic this link or video and your ready to attach the hoses to the valve cover and catch can.
    http://www.honda-tech.com/showthread.php?t=2150049
    http://www.youtube.com/watch?v=aDSozy6MZto
    *edit*
    Here are the final results
    Thanks to Blueridge Motorsports for the Catch Can, and DG Performance for TIG welding the bungs to the valve cover.
    If I missed anything, just pm me and I'll add it to the post.
    stockbridge
    not even in ga anymore and still bringing the heat. good job my brother.
    Slow&InControl! LokiSays's Avatar
    I got my valve cover vented for my b20vtec.
    ALL CAPS JITB's Avatar
    could you just run it back through a pcv and through the intake back in the motor like it is oem? I always thought just releasing all that pressure would do more harm than good...of course there are extreme cases..but..u know!
    Privateer Racing!!
    Duluth,Ga
    Venting your valve cover helps a little, But venting the block is what really helps with blow by and stuff.
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by JITB View Post
    Its not just pressure its releasing. Theres alot of oil and nasty shit that wants to come out too when you have all that pressure. You dont want to be feeding that back into your motor.
    EDIT: over read were you said filter it through the pcv. Sooo idk.lol
    ECEFC.com
    Quote Originally Posted by Halfwit View Post
    Thanks homie
    If you are talking about th3 hoses that goes from the air box to the valve cover, it won't work. Most people believe that line is there to "suck" out the flumes in the valve cover, but it doesn't. It actually pushes air into the valve cover so the flumes can go through the PCV system. Unfortunately, OBD2 B18bs and B20s have the PCV system incorporated into the valve cover. So when you swap heads, it deletes the PCV system totally.
    You can see the hole at the top center for the PCV valve.
    Quote Originally Posted by B18c1Turboed View Post
    I agree 100%. I had a debate with someone on CarolinaHondas.com about the the block vs valve cover. I actually decided to vent both the block and valve cover.
    Cobb County
    Quote Originally Posted by bigdare23 View Post
    How do you vent blocks? (I fail at googling apparently cause I didn't find anything)
    Also a question for the original subject: Is there a certain compression you have to reach before you start venting VC's and blocks? Like do you have to be a 13.1:1cr to worry about venting?
    Edit:
    Also does obd1 builds have the same problems?
    YOURMOM tnomud's Avatar
    Coweta
    I will be doing a write-up on how to vent blocks in the coming days.
    Privateer Racing!!
    Duluth,Ga
    Very easy Remove the Pvc box and then remove the 2 15mm Hex on the back of the block.Then you buy the 2 fittings too screw in there and run lines too a catch can.
    ECEFC.com
    If you're venting the block you will need these fittings
    ECEFC.com
    Quote Originally Posted by Just_CHill View Post
    Edit:
    check out my post above for the part #s to vent the block.
    Motors that have pcv system "don't" have to be vented, but that doesn't mean you wont benefit from it. Any motor (including stock) will benefit from relieving crankcase pressure.
    Cobb County
    Great info. Thanks for the response guys!
    oooh so this is just a honda thing?
    I always see people with those breather filters on their valve covers, when they get aftermarket intakes... which is always doing more hurt than good...
    cool, so how do you this for rotary? lol
    Peek-a-boo mofucka what now?!
    ECEFC.com
    Exactly! But ricers will be ricers...
    LOL
    LOL
    oh i was using my mazda brain.....lol
    Certified Gearhead jojeezek's Avatar
    Jul 2009
    what about D16s or D15B's? Do they need this as well?
    D16 + Turbo = The Replacement for Displacemnt
    Oct 2009
    Warner Robins, GA
    awesome write up man!
    Titties!!!
    so basically i have a jdm b16a 2nd gen but am hooked up obd-2b so i don't have to worry about all this do i, i remember everyone putting the little filter on the valve cover but that wont hel me. my hose runs from the VC to the intake so i guess im good. this will make me rethink a b20 bottom end on my car. also would venting my block be a good idea and very costly, i'm ballin on a budget til the ball joints are done and CV axle.
    Hwy 315
    i love you, thanks.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Certified Gearhead 94ej2's Avatar
    Mobile, AL
    Z10 makes the -AN fitting for the block too.
    You don't want that sludge from the block to go into your intake where it's sucked in coating the injectors, spark plugs, gunking up the valves, and top of the piston where it's just going to burn anyways. A catch can allows the crankcase to vent while preventing the sludge from being recycled and burned.
    Dragsters have been known to run vacuum pumps from the PCV system freeing up to 50hp...but I think the NHRA banned it lol!
    Quote Originally Posted by preferredduck View Post
    You'll get very little, if any, bloy by from the valve cover. I've always run my block through a catch can and the valve cover to the intake and my intake manifold was always spotless.
    Woodstock
    Can you have one decent size can to catch both, the head and the block? Instead of having 2 different catch cans? I am boosted and have some blow-by, was told (by reputable shop) my crankcase pressure was way too high.
    Northwest Georgia
    i have 2 off the valve cover and 1 off the block. 8an
    140 on one wheel
    columbus, ga
    im just venting my valve cover CFT's 8 sec. hatch doesnt vent there block just two from the valve cover
    Titties!!!
    Quote Originally Posted by speedminded View Post
    good info for sure.
    ECEFC.com
    Quote Originally Posted by Slomaro Z28 View Post
    Yea you can without any problems. With me having a CRX my engine bay is kind of cramped, so it's easier just to run two different (small) catch cans.
    ECEFC.com
    Oh yeah, here's the finish product
    SwiperNoSwiping!!
    you mentioned removing the Pcv box on the back of the block.... just wondering, what would you use to cover up that hole where you removed the box, or would it just be opened up to the atmosphere??
    u remind me of a wigger !
    KILL jody754's Avatar
    silvercreek,ga
    www.MSSracing.com
    MAINSTREAM PERFORMANCE
    Or you could just get a freeze plug from the part store to plug it off. Its only like a dollar versus the thirty plus shipping
    ECEFC.com
    Bump because I added better pics of everything assembled in the 1st post
    your right hand man 97_luder's Avatar
    so does the catch can need to have the filter on the top? what is the main difference between #1 and #2
    1.http://www.pdm-racing.com/products/i...can3-large.jpg
    2.http://www.tpis.com/catalogimages/LS1_Catch.jpg
    thanks
    Jan 2010
    We can do business
    wow now I just wish I can do that... Good Job!
    are the plugs on the back of an jdm h23a block oil or antifreeze?
    In GA; Missing NJ
    U plugged the stock catch can.. and you put fitting in the other two lines and ran another catch can.. i am lost.. I have put the catch can plug in...and was going to get the b&r catch can with the drain back.. what do you suggest? Or should i run two catch cans? One for the valve cover and one for just the block.. i am kind of lost now..
    ECEFC.com
    Quote Originally Posted by 97_luder View Post
    thanks
    Me personally, I would use a vented catch can (with a filter). The filter will allow the vapors to escape the system while keeping the excess oil in the catch can. Honestly, I don't know how a non vented catch can relieves pressure if it's just a closed loop.
    ECEFC.com
    Oil
    You wouldn't want to vent antifreeze would you?!? LOL
    ECEFC.com
    Quote Originally Posted by civic-r11 View Post
    I have a b20 which doesn't have a black box on the back. I just removed the two plugs on the back of the block with a big ass allen key. Then I replaced those two plugs with that nipples (part #'s shown in the picture above). I ran a hose from each nipple, then connected them to a vented catch can. The vapor goes out (relieving pressure), and any excess oil is caught in the catch can.
    Should you run two?
    That up to you and you motor. I had the block vented, and still noticed a few leaks. So I decided to go ahead and vent the valve cover to help assist the other catch can.
