Alright thanks for reading I have two accords and one was wrecked and the other had no motor. So heres the thing I swapped my 96 motor into my new 94 accord. Now when i crank it up it is in limp mode and will not go even when the car is in 1st it is a 5 speed f22b1 with a p2a5 stock lx trans. The clutch i had inside was going bad so i changes over from the new car with the blown motor clutch, pressure plate, and through out bearing all were good because the came with a bad motor with two rods broken but i drove the car into the garage. Everything is in properly i'm pretty sure about it. I have no idea what could be causing the problem please help!!!!!!!!!!!!!
