Results 1 to 20 of 20
Thread: oil burning
    unknown
    Default oil burning
    ok my car is burning oil WHY?
    West palm beach
    rings, valve stem seals or both, time for a rebuild...
    NO ADVERTISING
    -IA MANAGEMENT
    unknown
    do i go OEM valve stem seal or aftermarket?
    West palm beach
    Quote Originally Posted by Eg4LiFe View Post
    OEM
    NO ADVERTISING
    -IA MANAGEMENT
    unknown
    OEM
    ok thanks man
    what kinda question was this.
    roberta
    haha like uhhhhh undless things....
    f-ckouttahere. PROŽ's Avatar
    this may be the wrong place to ask this...a mod can move my question if need be.
    but,
    why does phone die when it hasnt been charged?
    My car burns oil too...... only, it's supposed to.
    JDM TYTE AnthonyF's Avatar
    The transducer for the flux capacitor isn't catalyicing properly. It's probably too far advance and needs to be reflashed.
    -Ant.
    The Carbon Fibered R6
    YR88 Win! Romeo's Avatar
    Middle Ga.
    It's a Honda you've modified in some way.
    Senior Member Patterson's Avatar
    Summerville
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    could be this but also-
    You know i thought about this all night. Here it goes, it might not be oil could be the blinker fluid over filling and spilling out on to the motor. this is caused by excessive blinking causing the fluid to overheat, so don't leave your blinker on to long. hope this helps
    I'll be willing to bet that the rings have a reverse taper on them.
    Titties!!!
    -Ant.
    it is the flux capacitor, it's a hyper drive problem. before i got the updated version from marty in the future i used to cover windshields with oil when hitting vtec!!!!
    Titties!!!
    Quote Originally Posted by Patterson View Post
    where do u refill this at, my blinker hasnt worked in a year and i cant find it in the haynes manual.
    6th Gear Junkie Andr3w's Avatar
    Carrollton, GA
    Do a compression test and post results.
    -2002 Subaru Impreza WRX Wagon
    -2004 Nissan Sentra SE-R Spec V *boosted* (parting out)
    Summerville
    Quote Originally Posted by preferredduck View Post
    haynes does not show it. you have to have a chiltons
    Newnan
    if you don't burn oil on initial start up, I wouldnt worry about replacing the valve stem seals, your just waisting time imo full engine overhaul to fix that bud
    Titties!!!
    thats where i went wrong. i found the fluid at auto zone but have had no idea where it goes.
    Titties!!!
    in all seriousness 99% of honda's burn oil when they get some miles on them esp if you taking it to redline often. that doesn't mean you need to swap the motor just yet. how much oil is it going through. vtec runs on oil pressure you know and usually the rings go first and you burn some oil. post up how much it uses how often and how many miles you drive to do so. you should be ok just always check the level before driving.
