 Originally Posted by
Hektik
				I'm in Gwinnett and I believe your on the southside correct? So it might be a pretty good distance.. Really I dont want to do them myself. Mostly cause I have attempted this in the past with one of those bernzomatic torches and it just didnt sem to get hot enough to actually cause the spring to compress under the weight of the car...Then again I'm not sure if I used propane or propylene, honestly im not sure which one gets hotter or if these are even the proper ones to use.. I'm pretty decently mechanically inclined so if you could lead me in the right direction I beleive I can accomplish this on my own... otherwise I would take it to a shop and see what they charge...
Also how do the springs hold up after being heated. Will I loose any of the advantages to the handling.
preciate it....
