Results 1 to 22 of 22
Thread: Serious concern with the SRT4...knocking?
    Certified Gearhead LvnBoOst's Avatar
    Jun 2009
    Exclamation Serious concern with the SRT4...knocking?
    Or what I think is knocking? lulz
    Ok, so last night my car decided to lose its power steering abilities, along with a loud dinging noise, accompanied by a stall & oil light. Right as I turned into a neighborhood...
    1. I checked the oil level, fine. I just had it changed like 30 days ago.
    2. It only has like 70K miles on it [Not a clunker, even though it is a neon.]
    3. I've never had issues with it before, no symptoms leading up to this disaterous event.
    So serious opinions ONLY....Im trying to get some info before I have it towed somewhere this evening.....Kthx
    Quote Originally Posted by changaroo View Post
    jesus-tapdancing-christ.
    Woodstock
    My first thought would be a spun bearing or a rod knocking.
    Did it sound like this?
    http://www.youtube.com/watch?v=DfJIpiQZtR4
    Jun 2009
    Im @ work. Fail. I dont have speakers. I will check it from my phone in a little bit.
    Had one knock, then lock up. It ended up being the bolts in the flex plate backed out and locked up against the motor...
    Jun 2009
    Yeah, Im really just not sure whats going on with it. This car has been great so far...
    I think Im going to take it somewhere...have it checked out and see what the damage is...
    Good thing is, it drives. Atleast the 20 or so feet that it does..
    Let us know if you need anything 678-363-6789.
    Jun 2009
    Alright, I definitely will, thanks!
    General Tech Hater
    Flexplate?? They made automatic SRT-4s??
    Jun 2009
    Quote Originally Posted by MidLifeCrisis View Post
    Woodstock
    No, still staying with my first thought.
    known as Charles
    No, from the factory the SRT4 has a clutch/flywheel combo that is made together and can't be taken apart. This whole thing bolts to a flexplate with 4 bolts just like a tq conv does. It is very common on the SRT4s for these bolts to come loose.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    BOOM HEADSHOT!
    Woodstock
    Quote Originally Posted by Main Stream View Post
    BOOM HEADSHOT!
    Got ya, wasn't aware they used these on the srt-4. I have seen them before, I think my old 2g eclipse was like this.
    Jun 2009
    I have an aftermarket clutch.....Competition Clutch, made for my car.
    So....its not anything to do with the clutch, I am pretty sure. Then again, anything is possible.
    So I moved the car this morning, pulled it into the driveway from the street and for a whole 20 seconds she ran good.....then (plop, plop, plop.....) and it died.
    Dont run it anymore, you're probably doing more damage each time you do. Depending on whether the engine can even be salvaged at this point. Does the oil light still come on while its running?
    Woodstock
    Quote Originally Posted by LvnBoOst View Post
    Back to my original theory
    General Tech Hater
    BOOM HEADSHOT!
    Ha, i was just pokin man, nothing serious. That is interesting to know, as i've never really read up on those cars or tinkered with one.
    .........sounds like you leaned out.........r you tuned?
    Warner robins ,Ga
    the woorst thing to do is to keep starting it!
    Killing it Since1982 bloodline's Avatar
    new york city
    have you did anythin to the car prior to what had happend? like install anything new ..use different type of oil..or change anything?
    how does the motor run when you put it in gear? does is feel shakey on low rpm?
    do you have trouble starting it? how does it idle?
    riding low is like a religion
    Jun 2009
    Quote Originally Posted by bloodline View Post
    Nothing. It has an intake...basically stock. I had the oil changed, but used full synthetic like normal...nothing out of the ordinary.
    Sometimes it kinda shakes when I put it into first gear, almost like its ablout to stall, but only once in a while. lol.
    Its weird because it was running great and then boom, out of nowhere, shuts off.
    Im having it towed somewhere Monday to see what the issue is.
    Personally, I think it is fuel related.....we shall see
    Jun 2009
    SRT4 is pulling 2 codes....Oil pressure sensor low and fuel pump relay circuit. WTF
