Thread: '98 Ford Escort Blower Motor Relay Location?
    What The Hell
    Kennesaw/Acworth
    Default '98 Ford Escort Blower Motor Relay Location?
    Needing to replace the blower motor relay on my sisters 1998 ford escort. only problem is i cant find it.
    Where is the blower motor relay located?
    Thanks for any help
    ALL CAPS JITB's Avatar
    in the fuse box, under the hood, u cant miss it! its near the battery
    or its on the passenger side, near the windshield.. it should be 2 relays, 1 for the a/'c and one for the blower motor.
    What The Hell
    Kennesaw/Acworth
    thanks ill check both out and let you know if i find it
    What The Hell
    Kennesaw/Acworth
    were you talking about the resistor or the relay?
    i found the resistor but couldnt find the relay in either spot
    Quote Originally Posted by 90_ACCORD View Post
    i was thinking it was the relay. the only relays on those cars are in the fuse boxs by the battery.
    is the heat not working?
    What The Hell
    Kennesaw/Acworth
    Quote Originally Posted by JITB View Post
    the blower motor isnt working at all and it was determined that the relay was bad and needed to be replaced. ill check for it again in the morning. thanks again
    if anyone else has any ideas let me know. hopefully i just overlooked it
    i cant find the manual i had for that car, but the previous years is soo much similar same chassis and everything. Its located next to the a/"c relay which is on the passenger side of the engine bay..top corner. under a rubber covering. because the resistor for the blower motor is on the plug of the blower motor, behind the glove box. You might want to check the fuse box, and look for a breaker button on top of the fuse box.. the previous years had a breaker button..
    What The Hell
    Kennesaw/Acworth
    thanks for all the help. got it all solved
